Join Today
User Tag List
+ Reply to Thread
Results 1 to 4 of 4
Thread: Water pump?
  1. #1
    Senior Member Array
    Join Date
    Aug 2008
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Water pump?
    Well ive just got home and check alternator came on the dash as i stopped. Got out and water is pissing all over the place. Im guessing its the water pump that has gone. Is this right? And how hard is it to change? Does the engine need to come out? Ive got to sort it 2moz as i need the car friday. So could do with some advice quick time. thanks
  2. # ADS
    Circuit advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Senior Member Array
    Join Date
    Nov 2007
    Location
    Eversley
    Posts
    6,197
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Check the aux belt the water pump might have collapsed so the alternator is not spinning. If the belt is tight it might be a water pipe that's popped. You can do it without taking the engine out take out the evap unit, power steering reservoir and expansion tank and washer tank then you can get to the engine mount as you need to undo this to jack the engine up to get to the pump nicely 3 x 5 or 6 mm bolts and a bit of a wiggle then it's out make sure the o ring comes out.
  4. #3
    Senior Member Array
    Join Date
    Aug 2008
    Posts
    222
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ok mate thanks for that, i will have a look 2moz. How much are water pumps roughly. Any idea?
  5. #4
    Senior Member Array
    Join Date
    Nov 2007
    Location
    Eversley
    Posts
    6,197
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Will let you know in a bit
Thread Information
Users Browsing this Thread
Similar Threads
  1. Aircon pump
    By Lucifer in forum For Sale
    Last Post: 25th November 2010, 07:43 AM
  2. water leak
    By 111Sum in forum Performance and Technical
    Last Post: 21st December 2009, 09:39 AM
  3. fuel pump
    By daniel1989 in forum General Chat
    Last Post: 9th November 2009, 01:20 PM
  4. R32/R36 VW water pump, brand new in box
    By peat_yt mk2 in forum For Sale
    Last Post: 13th January 2009, 02:07 PM
  5. HELP. Water Ingress
    By MIKE32 in forum Performance and Technical
    Last Post: 9th October 2008, 06:13 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
