R32OC | VW Golf R32 Owners Club
Thread: advise on running schrick cams
  • Share This Thread!
    • Share on Facebook
    1. #1
      Senior Member gazjones is on a distinguished road gazjones's Avatar
      Join Date
      Jun 2007
      Location
      Lincoln
      Posts
      836
      Default advise on running schrick cams
      what exactly is needed to go along with the cams? the reason i ask is at my local vw dealer on owner has just put his car back to standard, so had cams taken out. the service manager has mentioned that he also changed the fpr from 4bar to 3bar when the cams were fitted to the car? aparently this is due to the car over fuelling with the higher lift on the cam and duration.
      so anyone who has had the cams fitted could you tell me exactly what was needed or parts that were needed to be replaced at the same time? gaskets seals anything like that.
      also thinking while the inlet manifold was off, i would get the milltek manifolds fitted as it would be pretty simple at the same time?
      anyone had problems with timing chaines? poor blokes r32 that was at ve has had 3 sets so far so feedback from owners with these fitted would be great, good and bad feedback! take it your ok to drive the car for a little while to go and get it mapped?
      thanks in advance for any replies.
      www.vagautocareservices.co.uk
      R32 Full service inc haldex oil and filter £190
      Vag Com/ Vag Tacho, Alarm bleep auto locking, Miles to empty Lit needles enabled
    2. # ADS
      Circuit advertisement
      Join Date
      Always
      Location
      Advertising world
      Posts
      Many
    3. #2
      Senior Member goodboy1451 is on a distinguished road
      Join Date
      Apr 2007
      Location
      Fleet Hampshire
      Posts
      381
      Default
      Upgrade mine to a 264/260 schrick, no other parts changed as was advised by tuner. However, you need to ensure that the two rubber rings (5p diameter) on each stock cams is put onto the schrick cams.
      Been running fine since.
    4. #3
      Join Date
      Jun 2007
      Location
      Lincoln
      Posts
      836
      Default
      cheers for your views, did you have it remapped after?
      anyone else had the camms fitted, must be some others
    5. #4
      Join Date
      Apr 2007
      Location
      Fleet Hampshire
      Posts
      381
      Default
      Stealth racing Vince did the remap. you MUST remap after the cams, else its pointless to do the mod.
    6. #5
      Junior Member newcreation is on a distinguished road newcreation's Avatar
      Join Date
      Oct 2007
      Posts
      27
      Default
      Cams and reflash worthwhile mod if your not willing to go FI
      ALL MOTOR R
      TT cams,Giac 7300 Rev cam flash,SS headers,Usp test pipe,neuspeed cat-back,Evoms v-flow,plus a boat load of other mods
    7. #6
      Administrator khutula is on a distinguished road khutula's Avatar
      Join Date
      Mar 2007
      Location
      Cheshire
      Posts
      2,979
      Default
      I am running uprated Schrick 268 CAMs and nothing else needs changing.
      Most R32s has a 4 bar fpr anyway.
      Get a decent remap and it transforms the car - well worth it.
    8. #7
      .:R32OC Site Contributor wrk_in_progress is on a distinguished road wrk_in_progress's Avatar
      Join Date
      Aug 2007
      Location
      somerset
      Posts
      3,762
      Default
      I'd love to get cams but every time I start to save something else comes up LOL.
      Milltek Manifolds, Sports cat and Non Res Carbonio CAI 25mm Rear Spacers Alpine W502 TST rear stress Brace Anthracite Astros
    9. #8
      Member tottyr32 is on a distinguished road
      Join Date
      Jan 2009
      Posts
      38
      Default
      i have just purchased a set of 268 cams, after a remap with milltek ex and decent filter what bhp should i expect? do these cams kick in at high revs or mid?
    10. #9
      Join Date
      Jun 2007
      Location
      Lincoln
      Posts
      836
      Default
      ill be doing a write up soon on the fitting of milltek manifolds and the cams, geting a remap at stealth next wednesday.
    Thread Information
    Users Browsing this Thread
    Similar Threads
    1. Which Schrick Cams?
      By James32 in forum Performance and Technical
      Last Post: 5th July 2009, 09:13 PM
    2. schrick 268 cams mk4 R32
      By gazjones in forum For Sale
      Last Post: 5th June 2009, 07:24 PM
    3. schrick 264 cams...
      By david5390 in forum For Sale
      Last Post: 22nd May 2009, 03:53 PM
    4. Schrick 264 r32 NA cams
      By Alex303 in forum For Sale
      Last Post: 19th May 2009, 06:45 PM
    5. Schrick cams
      By stoltos in forum General Chat
      Last Post: 25th May 2008, 05:29 PM
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
