R32OC | VW Golf R32 Owners Club
Thread: BMC Induction kit
  • Share This Thread!
    • Share on Facebook
    1. #1
      Member ghostfacesuk is on a distinguished road ghostfacesuk's Avatar
      Join Date
      Mar 2009
      Posts
      40
      Default BMC Induction kit
      Hello all,
      I have been looking at the BMC enclosed induction kits for the MK4 R32. I would like to know a few things before I get one.
      1) Is it worth getting one for a start, I guess the idea of them is to be less restrictive than then standard air box but does it actually help?
      2) How easy are they to fit and what tools would I need?
      3) If I got one would I need to get an oil catch tank?
      4) Is there a better filter than the BMC one? If so why?
      I am not sure if there is a similar thread on here about this; if there is could someone be nice enough to point me into the right direction?
      Thanks in advance,
      Steve
    2. # ADS
      Circuit advertisement
      Join Date
      Always
      Posts
      Many
    3. #2
      Member Bluelion is on a distinguished road
      Join Date
      Jun 2008
      Posts
      89
      Default
      (1) I assume you're talking about the BMC CAI? I fitted one to mine and the dyno results were greatly improved. Bearing in mind I've got other modifications (full exhaust + remap) I saw an incredible +22hp gain on the rollers on Saturday just from changing the filter to a BMC.
      BUT... I noticed last night looking at the pre-BMC rolling road chart that the rev limiter cut it before at 6800rpm, and on saturday at 7200, so I'm actually wondering if I took the right graph home last year (despite it having my registration on). This would certainly explain the differing results, as I find it very surprising that the filter made this much difference. Nothing else was changed though - same dyno just 18 months apart and 1 BMC CAI fitted in place of a Pipercross panel filter.
      (2) Easy, you only need a couple of screwdrivers and sockets to remove the old one. Be careful you don't damage the MAF, and its quite fiddly feeding the air tube down to the lower vent - I removed the battery for better access. Give yourself a good 4 hour session to do it steadily, you might do it a lot quicker (a pro would do it in under an hour I'd guess) but that's about the length of time it took me.
      (3) Er well I haven't. Not sure I understand why you think you might need one of these? You're only replacing bits on the open side of the MAF, not the engine side.
      (4) People like the Carbonio kit so will probably recommend that. I didn't want this kit at it puts the filter down directly in the air flow behind the passenger side lower vent. I didn't want it getting soggy when traveling along in the rain - the BMC kit keeps the filter in the engine bay thermally insulated from the engine heat by a carbon fibre casing (at least I think its CF, its certainly CF-like if its not!). I think the BMC is a bit more expensive than the Carbonio though.
    4. #3
      Join Date
      Mar 2009
      Posts
      40
      Default
      Thank you for the detailed reply, that has cleared a lot of things up.
    5. #4
      .:R32OC Site Contributor DWolfUK is on a distinguished road DWolfUK's Avatar
      Join Date
      Feb 2008
      Location
      Houghton Regis
      Posts
      4,854
      Default
      the BMC CDA is carbon (Carbon Dynamic Airbox) - its what i have on mine for the same reasons as bluelion - i noticed an improvement in drivability after fitting but no RR charts to compare.
      Full VCDS, Vag-Tacho, VDS-Pro Owner (Can Do: Miles To Empty, Lit Pointers, Remote Windows, Alarm Beeps)
      VAG-Com Location List ¦ Recommended Wheel Refurb Places ¦ Recommended Detailing Suppliers ¦ Usefull DIY Guides MK4 & MK5
    6. #5
      Senior Member celica is on a distinguished road
      Join Date
      Feb 2009
      Posts
      1,791
      Default
      i had one on the TT and loved it and miss it ;-(
      "I must not mod"
      MKV Shadow Blue
      Considering a 535d Touring/ Audi A6 Avant 3.0tdi - anyone up for a swap?
    7. #6
      Join Date
      Feb 2009
      Posts
      1,791
      Default
      any pics of what it looks like in the mk5?
      "I must not mod"
      MKV Shadow Blue
    8. #7
      Member Supersprintuk is on a distinguished road
      Join Date
      Jul 2008
      Posts
      40
    Thread Information
    Users Browsing this Thread
    Similar Threads
    1. Induction kit - anyone tried this?
      By Bowser in forum General Chat
      Last Post: 6th April 2010, 07:20 PM
    2. R32 Induction kit
      By Callum in forum Awesome GTI
      Last Post: 5th January 2010, 09:35 AM
    3. need induction
      By logic7654321 in forum Wanted
      Last Post: 28th September 2009, 09:13 AM
    4. Induction kit
      By kernowr32 in forum General Chat
      Last Post: 22nd September 2009, 10:27 PM
    5. The best induction kit.
      By dme in forum General Chat
      Last Post: 20th May 2008, 05:23 PM
    Tags for this Thread
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
