Register Members List
Forum Search:   Power Search
Forgot Password?
Not Registered?
ad
R32OC | VW Golf R32 Owners Club > Car Specific > Performance and Technical >> K&N Panel Air Filter
K&N Panel Air Filter Thread title: K&N Panel Air Filter
Reply
LinkBack  Thread Tools  Search this Thread  Display Modes
Old 30th October 2008, 12:13 PM   #1 (permalink)
Default K&N Panel Air Filter
Andy R32's Avatar
Status: Junior Member
Andy R32 is on a distinguished road
Hi everybody, I'm soon gonna replace my air filter with a K&N Panel Air Filter. This is the type I want because it's a straight forward swap and it fits into the factory box. I would like to know if anybody else has used the same type of air filter and make sure that it's good for the car etc? Andy
Click the image to open in full size.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 30th October 2008, 12:28 PM   #2 (permalink)
Gti Fly is offline   Gti Fly
Default
Status: Senior Member
Gti Fly is on a distinguished road
I've been using one in my R32 for over 60,000miles. It give a little more noise, and seems to help give that little bit extra bite.
Old 30th October 2008, 12:32 PM   #3 (permalink)
burble is offline   burble
Default
Status: .:R32OC Site Contributor
burble is on a distinguished road
I've heard comments about K&N filters losing their oil and upsetting the MAF. I was running one which I replaced with an ITG filter before replacing that with a CAI.
__________________
Gone, not a member here any longer.
Old 30th October 2008, 02:07 PM   #4 (permalink)
Default
Andy R32's Avatar
I've also read a comment about that problem too if they are over oiled. I don't think i'll bother getting the K&N filter. Do you know how much those ITG filters cost? Larkspeed said K&N would be just over £40. Andy
Old 30th October 2008, 02:39 PM   #5 (permalink)
Default
I think mine was about £60.
__________________
Old 30th October 2008, 02:42 PM   #6 (permalink)
DWolfUK is offline   DWolfUK
Default
DWolfUK's Avatar
DWolfUK is on a distinguished road
Send a message via MSN to DWolfUK
i had good results with a green panel filter on my mkiv. i try to avoid K&N after all the horror stories although im sure load use them without issues. I went straight for the bmc intake on the mkv and although expensive i think its worth it.
__________________
Full VCDS, Vag-Tacho, VDS-Pro Owner (Can Do: Miles To Empty, Lit Pointers, Remote Windows, Alarm Beeps)
VAG-Com Location List ¦ Recommended Wheel Refurb Places ¦ Recommended Detailing Suppliers ¦ Usefull DIY Guides MK4 & MK5
Old 30th October 2008, 03:22 PM   #7 (permalink)
Default
No worries with KN being oiled, I've run my one for 60,000 miles plus without any horror stories
My dad's got one in his Subaru STI remapped to 320+bhp, and has no problems either.
In my opinion KN have suffered from ppl on the internet giving out scare stories, I've not experienced any problems at all
Old 30th October 2008, 07:06 PM   #8 (permalink)
FLYER is offline   FLYER
Default
FLYER's Avatar
FLYER is on a distinguished road
Yes i have the k&n panel filter on my car.ive had no problems at all.
but every 3 weeks i take it out of the air box and i give it a good shake out.its surprising how much dust and crap comes out.+ i like it better than an induction kit as you dont get heat soak..
Old 30th October 2008, 07:35 PM   #9 (permalink)
Default
DWolfUK's Avatar
id have expected less "heat-soak" from a properly fitted induction or intake kit.
i know on mine the air is a lot cooler both whilst sitting still and moving with my BMC intake than the factory one. i did some tests with vag-com before i handed over my money. the difference wasnt a lot on a quick fit but i only had a day to test and i couldnt fit it properly without modifying it. Once i had paid and could chop it etc i was really pleased with the results.
__________________
Old 31st October 2008, 09:22 AM   #10 (permalink)
Default
Macdaddy's Avatar
Status: Administrator
Macdaddy is on a distinguished road
You'd get less way less heat soak over one of those under the bonnet cone filters. But compared to a decent CAI like Carbonio the air will be warmer. Simply due to where the filter is placed.
However performance gains BHP wise are pretty much not worth discussing between the different kits.
__________________
Mk4 .:R32 2006-2008
Mk5 .:R32 2008-2009
Range Rover Autobiography 4.4 V8 2009-
www.350zoc.com Nissan 350z Owners club
Old 31st October 2008, 01:16 PM   #11 (permalink)
Default
Those carbonio CAI are more prone to sucking up water when the roads are really wet, or if u hit a big puddle (we've all done that at night when we least expect it), and then f up the engine.
Now there's lots and lots of stories of this happening recently on the uk-mkivs forum.
Proof if any, that you should stay away from those airfilters which route into the lower engine bay area
Old 31st October 2008, 04:15 PM   #12 (permalink)
Default
DWolfUK's Avatar
i agree and wouldnt touch anything that moves the intake to the bottom of the car. but most of the newer kits on the mkv especially use the stock air intake on the grill and so dont suffer from this problem.
__________________
Old 3rd November 2008, 11:39 AM   #13 (permalink)
Zeegoff is offline   Zeegoff
Default
Zeegoff's Avatar
Status: Member
Zeegoff is on a distinguished road
I had one of those type filters on my last car, K&N typhoon cold air scoop ran down infront of the passenger wheel, went thru a big puddle by accident, ended up needing a new engine, NEVER again.....
Old 10th November 2008, 05:59 PM   #14 (permalink)
Silver is online now   Silver
Default
Silver's Avatar
Silver is on a distinguished road
So what would you recommend for the mk4, a filter?
Old 10th November 2008, 06:16 PM   #15 (permalink)
Default
a K/N panel filter mate. nothing fancy, just replaces the OEM paper airfilter
Old 10th November 2008, 06:32 PM   #16 (permalink)
Default
wrk_in_progress is on a distinguished road
I must admit I've had a carbonari for about abyear now and touch wood I've never had any problems. I just make sure I takenit steady and watch for the puddles. Not to say I haven't hit one in the dead of night.
Old 10th November 2008, 06:37 PM   #17 (permalink)
Default
Silver's Avatar
Hmm not really into k&n much, maybe a different panel filter
Old 10th November 2008, 07:12 PM   #18 (permalink)
Default
DWolfUK's Avatar
Quote:
the bmc kit is pretty good. just dont route the piping to the bottom grill
__________________
Old 10th November 2008, 07:39 PM   #19 (permalink)
Default
BMC do filters.
personally I dont think a dry foam filter is any good, if you hold any of these filters upto the sunlight you will notice that you can see right thru the mesh quite easily. This can't be good for filtration levels, but I guess this is the chance you take when you upgrade filters
Old 11th November 2008, 12:38 AM   #20 (permalink)
Default
James (caxton01)'s Avatar
James (caxton01) is on a distinguished road
Quote:
Hummmm, Bazz
I was comming back from Cambridge this afternoon and the roads were water logged (Just creaping through the water about 5-10 mph)
Dont think I would like a air intake that was sucking air from down by the lower grill intake. :mad:
Just worried that the water would have ben sucked into the engine !
__________________
James
2003 (53) DBP - FULL LEATHER - MILLTEK NON RES - DELOCKED DOORS - DOOR ALARM BLUE LED's - CARBONIO COLD AIR INTAKE - BLUE SPORT HALDEX CONTROLLER - UPGRADED BRAKES FROM JORDAN'S GROUP BUY - WITH PROJECT U PADS - FRONT (25mm) and REAR (21mm) H&R ARB WITH DEFCRON2 BUSHES - FULL INSTULATION OF LED BULBS - MK5 REAR WIPER - SEAT CUPRA FRONT SPLITTER - VENTED FRONT SIDE GRILLS - VW CENTRE WHEEL CAPS - R32 TAX DISK - "R"-SIDE DECALS - DBP ENGINE COVER - DBP REAR VW BADGE - R32OC.COM STICKERS
Old 11th November 2008, 09:26 AM   #21 (permalink)
Default
TwoCollieForThirty's Avatar
TwoCollieForThirty is on a distinguished road
Quote:
Originally Posted by caxton01 View Post
Hummmm, Bazz
I have the Carbinio CAI fitted to mine for over a year now and its not caused me any real problems and it sounds spot on! BUT dont go through any big puddles as it sits about 8 inches from the ground. I've had to do 3 point turns in the middle of the road before to avoid floods, people look at you like your mad, lol
__________________
Loads of mods but i cant be arsed to type them...........oh but its got a 3.2 V6!
Old 11th November 2008, 09:26 AM   #22 (permalink)
Default
Hummmm, Bazz
It does make driving rather nerve-racking.
Old 11th November 2008, 02:45 PM   #23 (permalink)
Default
Quote:
Yes I bet it does
(Someone had a 4x4 and they did not want to go through the water,....... May get it dirty,lol )
__________________
James
Old 13th November 2008, 07:25 PM   #24 (permalink)
atomic is offline   atomic
Default
atomic is on a distinguished road
if you are worried about hydro-lock with a CAI I would recommend you fit a AEM Air Bypass Valve. AEM - Air Bypass Valve for Cold Air. Not a really CAI man myself always prefer a simple panel filter though I do have a BMC CDA on my hillclimb car. Have a BMC panel fitted to the R but have tried most others in various cars over the years and too be honest they are all about the same. You won't go wrong with a K&N.
Old 13th November 2008, 08:57 PM   #25 (permalink)
Default
Nice one atomic. Do you know if AEM have a U.K distributor or if I can get one on the Uk??
Reply
Search this Thread:
Advanced Search
Forum Rules & Jump
Posting Rules
Smilies are
[IMG] code is
HTML code is
Similar Threads
Thread Thread Starter Forum Replies Last Post
K&N Panel filter 33-2384 DonnieDarko General Chat 3 10th February 2010 01:29 PM
MK5 K&N Panel Filter army_james For Sale 0 11th November 2009 10:36 PM
K&N Panel Air Filter Mk5 & LCR Splitter Jonny For Sale 9 17th July 2009 12:06 AM
Servicing For R32 / Aftermarket Panel Air Filter R32 mad General Chat 5 9th October 2008 06:23 PM
15% off Carbonios khutula General Chat 24 3rd October 2007 06:02 PM
Revo
Contact Us  |  R32 Owners Club  |  Archive  |  Top R32OC.com Copyright ©2009 R32oc.com
