Exhaust Emission Warning Light. should I worry?
24 replies to this topic
BraveStarr
BraveStarr
  • 87 posts
Hello!
Bought me a R32 mkIV yesterday.
:D
today driving home from work, the Exhaust Emission Warning Light, lighted up. not blinking.
Engine running fine, no missfires.
turned the vehicle off. and started again. the light didn´t dissapear.
a couple of hours later I disconnected the batteri for one hour.
And when I connected the battery again and started it, the up warning light went out.
I´m going for a short ride soon, and hopefully the warning light won´t come on again..
BUT do need to worry about this?
defianty
defianty
  • 132 posts
Have search on the forum mate. It's a common problem. Mine turned out to be a temperature sensor. Best to get in linked up to a VAG COM and see what the error is.
I drove mine for a few days and then started running a bit bad. The sensor was less than £30.
Good luck
Stephen
'04 MKIV R32 Indigo Blue
'73 Porsche 914 2.0
16vTej
16vTej
  • 842 posts
yeah i had mine come on a week ago... was the coolant temp sender... not too bad to change at all and only £25ish from VW
BraveStarr
BraveStarr
  • 87 posts
I installed a Typhoon K&N kit.
is it possible to see the error code anyway? One connector is disconnected due to the kit.
And I heard that it will be some error codes due to that.
GazJones@VACS
GazJones@VACS
    Official .:R32OC Sponsor
  • Official .:R32OC Sponsor
  • 1,283 posts
what sensor is disconnected? ive had the light come on twice for 2 different reasons. one time was due to my cats being for the want of a better word fuc**d and secon as said before temp sensor
HGP 520BHP TURBO MK4
www.vagautocareservices.co.uk
R32 Full service inc haldex oil and filter £200
Vag Com/ Vag Tacho, Alarm bleep auto locking, Miles to empty Lit needles enabled
Mattchaps
Mattchaps
  • 5,608 posts
I too have had it come on due to the temp. sensor.... it was on for a few days, then went off for a week, then came back again.
VAG COM will tell you for sure.
Audi R8 - 4.2 V8
*SOLD* - Audi TT-RS APR Stage II | VWR intake | APR RSC TB Exhaust
*SOLD* - JBS GTS440 Turbo'd .:R32
thisnamesux
thisnamesux
  • 75 posts
mine went into vw last week for this very error....
mine was temp. sensor... but also (don't want to worry people) the timing chain had stretched.
its goin back next week to get changed over... this can also cause the light to come on.
blackpug
blackpug
  • 572 posts
I've a typhoon too. This plug goes onto an engine breather solenoid. The hose to this should be connected straight to the typhoon pipe. Won't give an error.
BraveStarr
BraveStarr
  • 87 posts
ty all!!
I went to a mechanic and hooked it up to a computer.
missifring on cyl 4,5,6
lambda1
reseted the errors, started it up for 1 min.
no error codes
why?
I should mention that the car has been still over the last winter in a garage with the temperature of a normal home. All fueled up.
maybee the old fuel could be the problem?
GazJones@VACS
GazJones@VACS
  • 1,283 posts
or you have some coil packs on the way out thats why its not sparking properly leaving unburnt fuel passing through exhaust and lambda sensors are picking it up
BraveStarr
BraveStarr
  • 87 posts
Yeah!
It´s more likely to be the coilpacks.
I´m going to look the price up at a retailer.
Is it a difficult procedure to remove and reinstall the coilpack?
andysR32
andysR32
  • 1,838 posts
Think they are about £20 each,should take about 2 mins to change,just disconnect the wiring plug and then pull them out.They can be a bit stiff sometimes so you may need to pull it quite hard.
16vTej
16vTej
  • 842 posts
id say leave it for a while... could possibly be moisture build up if the car's not driven for a long time
a good drive that get's some heat into the engine will help alot to not only clear out moisture around the engine but also from within
BraveStarr
BraveStarr
  • 87 posts
TY again!
Is it possible to order these from England?
Live in Sweden and 1 coilpack is about 40£ here
and if I still have the problem I have to order three of them.
myabee Ill save 40 £ or so.
EDIT:
My english isn´t so good. is Coil Pack and Ignition coil the same thing?
BraveStarr
BraveStarr
  • 87 posts
or maybee from the US?
Dollar is low value now
#16
16vTej
16vTej
  • 842 posts
yes the ignition coil is the same thing as coil pack
would it be cheaper direct from Germany? that's where they are made i think
#17
BraveStarr
BraveStarr
  • 87 posts
Hmm maybee.
Do you know any webshop in UK / US or Germany?
I´m going to order all six of them. and change them.
#18
BraveStarr
BraveStarr
  • 87 posts
#19
MoJo
MoJo
  • 22 posts
www.eurocarparts.com
www.vagparts.co.uk
#20
BraveStarr
BraveStarr
  • 87 posts
Linked it up with vagcom now..
It said Too high signal from coolant temp sens.
plus signal from lambda.
What happens when the coolant temp sens is running bad?
#21
andysR32
andysR32
  • 1,838 posts
Hi mate,the coolant temp sensor is a common fault on VW's,but a reasonably cheap part to replace.You may have the green one which was early fitment,and now changed to black I think which is better.Think they are about £7 in uk so not to bad.As for lambda you're looking at about £100 in the UK but there are 4 of them 2 before and 2 after the cats.
Hope this helps.
#22
GazJones@VACS
GazJones@VACS
  • 1,283 posts
andy its other way round with temp sensors, black was early the green to fix the problems, cost me about 30 quid all in for sensor seal and new clip. then new anti freeze top up. but the temp sensor might be causing a fueling problem thats throwing up the lambda sensor fault.
#23
andysR32
andysR32
  • 1,838 posts
Cheers Gaz thought it was something like them colours just couldn't remember quite what.:confused:
#24
Macdaddy©
Macdaddy©
  • Administrators
  • 4,541 posts
I ordered the Green upgraded sensor and fitted it just incase.
The last time my emmisions light came on it was coilpacks, but the car ran like crap too.
www.audirs3oc.com
#25
BraveStarr
BraveStarr
  • 87 posts
Is this the right partnr?
1J0959481A
well actually I´ve been reacting over the fuel consumption. I think it eats gasoline like h*ell
And thats even when im driving to work. no hard driving. just cruising.
maybee its the coolant temp sensor causing this.
or maybee the car has this consumption ;)
(the car runs good, when I hooked up through a vagcom there were no missfiring error)
