RNS-510 and OEM Bluetooth with red MFD+
5 replies to this topic
sixteen10
sixteen10
  • 131 posts
Hi Guys
I have seen very few threads with substantial info on this so I am hoping someone can give me a good heads up as to what I need:
1. I am in the process of buying an RNS-510 and want bluetooth installed at the same time. I currently have an iPhone 4S , will the OEM system work with my phone?
2. In the event that it does , what functionality will I get through the MFD and my RNS? Will I be able to dial and answer calls from my RNS as well as my MFD ( with coding of course ) ?
Bear in mind I have no interest in streaming audio over bluetooth from my phone , I just want to be able to browse contacts through my MFD , answer off of my MFS and have the same functions through the RNS510 itself.
Will the 9W3 premium bluetooth module work?
Grant
birdiemachine
birdiemachine
  • 3,000 posts
I retrofitted a rns510 to my mk5 r32 mate, at the same time i installed a mobridge bluetooth module, the beauty of this bluetooth module is it has a slot for a sd card so you can upgrade it at a later date to be able to deal with new phones etc etc, it's not that cheap but is really worth it and a doddle. I don't have a mfsw or a highline display so can't answer your questions about functionality regarding that.
I got my rns510 off n13kkf on here, he is very knowledagble in this area, hope this helps.
sixteen10
sixteen10
  • 131 posts
Thanks mate. Ended up using the oem 9W7 BT module and everything works great :)
BManLDN
BManLDN
  • 1,355 posts
  • LocationFrankfurt / West LDN
Hi mate,
May I ask if you can A2DP stream in stero from your phone via the Mobridge unit or does it come in mono?
SD card slot? Mine has a mini USB PORT for updating!
Everything (excluding a sunroof - shite option anyway)... and more!!!
birdiemachine
birdiemachine
  • 3,000 posts
Hi mate,
Unfortunately just mono mate
BManLDN
BManLDN
  • 1,355 posts
Ditto.....
