Decat Lambda Spacers??
19 replies to this topic
themainlegend
themainlegend
  • 1,534 posts
  • LocationCardiff
Hi all,
Been reading posts on decats and have seen a few people have added spacers. I am considering going down this route and don't really want EML on as it will only annoy me.
Has anyone got these spacers fitted with no EML?? Do I need a spacer on one lambda or both??
Cheers all.
PaulW
PaulW
  • Administrators
  • 16,103 posts
  • LocationThurso
Hi all,
Cheers all.
42 Draft Design do Lambda spacers
http://www.awesomegt...2-sensor-spacer
Its not guaranteed to work Lee, some people they work for then the light comes on and off at its own free will. Some people put the lambdas in with no spacer and the light is intermittant/off
R32_Wez
R32_Wez
  • 1,704 posts
Mine does this, they throw up an engine management light, so i erase the code with my cheap ebay reader and it stays of for days at a time :)
Wez
themainlegend
themainlegend
  • 1,534 posts
  • LocationCardiff
Wez, do you have a lambda spacer fitted on the pre cat sensor?? Been looking at this setup and 99% of people with the spacer fitted have had zero issues with EML.
PaulW
PaulW
  • Administrators
  • 16,103 posts
  • LocationThurso
He has them on post cat.
Jack32
Jack32
    Nappy Wearing Member
  • 859 posts
  • LocationCheltenham
but on the other hand my eml light is on constantly and i'm running the same setup as wez apart from a res section.
MK4 DBP
Milltek resonated with Gt100 tips
Evolution Motorsport Induction kit
18" Rotiform BLQ's
Lucifer Decat
Porsche 6 Pots
Airlift v2 kit Twin compressors 5G tank
MRC custom Remap FS/LC
H&R rear 15mm and 10mm Front spacers
My Flickr.!
PaulW
PaulW
  • Administrators
  • 16,103 posts
  • LocationThurso
You got lambda spacers Jack?
Either way i would recommend getting it mapped, spacers or not
eddgreen
eddgreen
  • 384 posts
  • LocationCirencester
Mines running APR stage 2 map done by awesome and milltek sports cats and the light still comes on for cat efficiency!
Jack32
Jack32
  • 859 posts
Naa was looking into them 42 draft have some great reviews but the spacers are like golddust and are on back order all over the uk.
MK4 DBP
18" Rotiform BLQ's
Lucifer Decat
Porsche 6 Pots
My Flickr.!
Lucifer
Lucifer
    Eats Kitty Litter
  • 6,629 posts
  • LocationCullompton Devon
you can get lambda spacers on ebay easy. Anyone that uses my de-cats will need a 90 degree spacer as my de-cats already have the lambda spacer made longer. If you add another spacer on top the lambda`s will be against the belly of the car.
http://www.ebay.co.u...cat=0&_from=R40
715 bhp turbo Mk4 Golf R32. Still wanting more power .
themainlegend
themainlegend
  • 1,534 posts
  • LocationCardiff
Lucifer, would I need 2 spacers for both post cat sensors??
So the L shape ones are best on your decats??
Lucifer
Lucifer
    Eats Kitty Litter
  • 6,629 posts
The L shape one are what you need. To be honest i don`t know much about Lambda censors and how they are configured in the ECU map to know if you could get away with one or not. For the price and hassle involved i would just buy and fit two as they are sod all really.
DougalR
DougalR
    South East Organiser
  • Regional Event Coordinator
  • 6,684 posts
  • LocationKent, near Canterbury
I used these dude with Decat...no warning light. its popped up once in a month now. cleared not come back.
I found them for 14 each on ebay. if not just search o2 sensor spacer
http://www.ebay.co.u...=item257d1b0fbf
May the boost be with you
.:Rotrex powered sleeper...well sort of.... :)
themainlegend
themainlegend
  • 1,534 posts
  • LocationCardiff
Dougal, have you fitted 2 spacers on each side of decat pipe??
Lucifer
Lucifer
    Eats Kitty Litter
  • 6,629 posts
There are only two bosses on the de-cat pipe so you only need two spacers.
#16
themainlegend
themainlegend
  • 1,534 posts
  • LocationCardiff
Sorted, cheers lucifer!!!
#17
Yohan
Yohan
  • 516 posts
  • LocationAberdeen
Would you not want your car mapped afterwards anyway to take advantage of the decat so then you could get them coded out at the same time?
#18
themainlegend
themainlegend
  • 1,534 posts
  • LocationCardiff
Yeah I do want a stage 2 custom map at some point but can't afford it just yet. Spent a fortune over the last few months and want to book a holiday for next year too!!!
#19
simonmac
simonmac
  • 1,237 posts
  • LocationSussex
Does anyone know the locations in the map to disable the lambda sensors? I can pull my map off and read it, but still getting to terms with finding the maps in the file.
VagCom/VCDS. VDS-Pro, VAGTacho, MPPS ECU Flash/Read, Fault code reading, key coding, SKC Pin code Retrieval, auto locks, remote windows, Miles to Empty, alarm beeps, lit needles, Immobiliser programming, Generic ECU Map Flash/Read. etc - based near Gatwick.
The Current Garage:
2003 VW Golf IV R32
1999 Subaru Impreza RB5
1995 Subaru Impreza 555 sti race car
2005 Renault Megane CC
2012 Mercedes E350cdi AMG Sport
2005 Jaguar X-Type 2.2D Sport Premium
1998 Audi A4 1.8T
**** Tiger Super 6
#20
Zig
Zig
    Semi-Advanced Member
  • 4,197 posts
  • LocationWest Mids
Just s word of warning you might get clearance issues between the top of the lambda probes and heatshield if you are running manifolds with your decat, pushing the heatshield up against the propshaft if you use spacers.
Only a minor issue as you can bend the heatshield so it dies not rub
