R32OC | VW Golf R32 Owners Club
Thread: Fitting aftermarket headlights to Mk4 R
  • Share This Thread!
    • Share on Facebook
    1. #1
      Senior Member nightSpirit is on a distinguished road
      Join Date
      Jan 2009
      Posts
      155
      Default Fitting aftermarket headlights to Mk4 R
      Some of you will have seen my post about black headlights for the R in the interior and exterior section. I'd sourced a supplier in Holland who'd assured me these lights (they are xenons) would fit straight onto the Mk4 R...
      No...
      They're fitment for Mk4 standard, not the R. The problem being that the R has 12 pin plugs and a different pin config than the normal Mk4 which is 10 pin...incorporating an internal fog where the second indicator lens sits on the R.
      I won't bore you with how to remove the bumper etc, just start with what I did to get them installed.
      The reason I started this install early, stone hits lens, stone wins.
      I got the Depo black headlights, without halo's and with a 6k xenon lamp.
      After a quick trip to Halfords to buy the bulbs used on the normal Mk4, that was one problem solved.
      I then went to my local VW dealer, Martin's in Camberley and ordered 2 10 pin plugs and 10 (2 pins on each wire) 2mm wires. As you'll see in fact you only need 6 pins to power everything as below:
      earth for side, ind and xenon
      earth for main
      positive for xenon
      positive for ind
      positive for side
      positive for main.
      I started by tracing the wires to the correct pins on both R32 and Mk4 lights (easy task) and working out which wires were actually needed.
      R32 lamp setup
      Mk4 innards
      And so I pinned up the plugs, making sure that the spare channels I wasn't using were plugged with sealant.
      Removing the plug and then wiring up the wires, making sure to wrap off the unused wires and wrap the soldered connections when done
      Before
      After, drivers side done. I located the remote ignitor under the plastic trim that runs beneath the headlight, it has a handy channel that the unit fits in perfectly.
      Passenger side before (which annoyingly has different coloured wires and an extra plug feeding the ignitor)
      And after. Now all you have to do is simply bolt them in (after testing them) refit the bumper and grill and then drive to a carpark to take photos of your handywork.
      If anyone needs the pinouts, what they do and where they go...let me know.
    2. # ADS
      Circuit advertisement
      Join Date
      Always
      Posts
      Many
    3. #2
      Senior Member Grant_R32 is on a distinguished road Grant_R32's Avatar
      Join Date
      Apr 2009
      Posts
      1,225
      Default
      You've done a good job mate! Nice 1
    4. #3
      Join Date
      Jan 2009
      Posts
      155
      Default
      Cheers Grant, I'm happy with the finish...didn't have an option though, fit these or buy a new drivers side unit!
    5. #4
      Senior Member amster is on a distinguished road amster's Avatar
      Join Date
      Dec 2008
      Posts
      603
      Default
      nice work mate
      many thanks for the info and the time/work to upload the photos/ and explaning..
      toms up..
      cheers mate
      Amster
    Thread Information
    Users Browsing this Thread
    Similar Threads
    1. aftermarket dub din
      By epons300 in forum Wanted
      Last Post: 9th April 2010, 05:42 PM
    2. Aftermarket alarms
      By BPH in forum General Chat
      Last Post: 8th January 2010, 06:14 PM
    3. Fitting an aftermarket HU
      By Obbzi in forum In Car Entertainment
      Last Post: 2nd June 2009, 08:39 PM
    4. Aftermarket Security
      By akita1 in forum General Chat
      Last Post: 30th August 2007, 11:41 AM
    5. Those of you with aftermarket exhausts....
      By Very Cherry in forum General Chat
      Last Post: 13th June 2007, 12:16 PM
    Tags for this Thread
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
