1 - 20 of 33 Posts
With the crazy money spent on turbo/supercharging an r32 has anyone tried shoe horning in a 4.2 v8?
ive seen some threds on mk 1 and 2's converted to rwd and caddys with the engine in the back ( saw a thread or a caddy the outher day with 2 s3 engines ,one in front one in back) but never a 32
seems like a good way to get masive reliable power
Am sure the v8 just to big for the actual engine bay, or you may need to move the engine mounts.
Remember the way audi do there engine is right over the front axel(if its the rs v8 you talking about)
Regards
Vrt
Yeah that another issue gearbox is massive in rs4's, and am sure a v8 engine to much power for a r32 gearbox.
Would be brill tho have a rs engine & performance wif a .:R shell(cosmetic)
Gav what v8 did you have in mind?
Since we kinda all jumped to audi rs engine.
Regards
Vrt
· Eats Kitty Litter
To big and heavy for an already nose heavy car plus why bother when you can get 1000 bhp from the standard engine unless you want to prove it can be done just for the hell of it.
Discussion Starter · #13 ·
Regards
Vrt
yep i was a passenger in an 02 rs6 the other day and was astounded by the power
as more companies are doing fi kits and more people are fitting them im hoping the price will come down a bit
On pistonheads
There is a cat d rs4 b7 going for £9000
The boy wrapped his motor.
Engine and car box are fine.
Just he dun the sides in.
It in glasgow.
Regards
Vrt
C5 Rs6 engine, i can't mind what the v8 in the rs6
But am guessing that will be even bigger then the rs4 block plus that only comes in auto
Regards
Vrt
spider said:
It's 4.2 biturbo in the c5 so probably the same size
Agree there,
Cause the comment put up wif the audi having the 2.7 bi turbo v6 look crammed into that engine buy.
So think it would be major work to fit a v8 in then there geaxbox issue's.
Regards
Vrt
Right found this
Engine Dimensions of Audi V8 4.2
http://models.audiusa.com/r8/detailed-specifications
Can't find the enginebay dimensions of a r32
But hopefully that helps a wee bit
Regards
Vrt
1 - 20 of 33 Posts
