Thinking about upgrading the speakers in my mk4 to some Focal components in the front.
I know I need the adaptors to go to 165mm speakers but I wanted to ask fellow members when they have done a similar upgrade where and how they have mounted the crossovers and if they have any pictures
I mounted the cross over of my focals onto the metal door frame thing, window regulator is it called? There's enough room for them under the door cards, don't worry
From memory you have to drill out the factory speakers, I mean you have to drill out the rivets which hold the speakers in.
Then it's a case of mounting the adaptor rings with nuts and bolts, and then screw the speakers onto the adaptors.
