Hello all,
I appreciate my car is not a R32 but I have had no luck on the Audi forums so need some help please.
Car: 2006 A3 3.2 Quattro DSG, Engine Code BMJ
I bought this car after the chain had been replaced, the car was misfiring heavily and the owner had got sick and tired of it. I checked the MBV's and thought to check the timing first, I found it was incorrectly set as the intermediate pulley was half a tooth out. I also found that the filter on the camshaft adjustment unit was damaged, I repaired this with the same grade mesh, stripped down the camshaft adjustor's and adjustment unit rebuilt and put the car back together.
The timing was set correctly, the car start and idles fine (checked cam positions in MBV's) but does lacks power. Looking at the measuring blocks below it appears that the camshaft adjustment unit is faulty, as the cam timing is not being adjusted as the ECU specifies. I am thinking it could either that the cam adjusment unit is getting any oil, or I have not put it back together correctly. Does anyone have any experience on this? Thanks
Address 01: Engine (022 906 032 GJ)
19:35:01
2680 /min Engine Speed (G28)
33.0°KW Adjustment (specified)
0.0°KW Adjustment (actual)
2.0°KW Adjustment (specified)
-2.5°KW Adjustment (actual)
124 Phase Position Intake Cam.
0.0°KW Intake Cam. Offset
73 Phase Position Exhaust Cam.
3.0°KW Exhaust Cam. Offset
Sunday,02,June,2013,20:54:13:19586
VCDS Version: Release 11.11.5
Data version: 20121222
Address 01: Engine Labels: 022-906-032-BDB.LBL
Control Module Part Number: 022 906 032 GJ HW: Bas isX 3
Component and/or Version: MOTRONIC ME7.1.1G 7001
Software Coding: 0000178
Work Shop Code: WSC 06314 000 00000
VCID: 59B3A0499055F0D0062
4 Faults Found:
18630 - Oxygen (Lambda) Sensor B2 S1
P2198 - 004 - Signal too High (Rich)
16424 - Oxygen (Lambda) Sensor Signals Swapped
P0040 - 008 - B1-S1 / B2-S1
16395 - Bank 1: Camshaft A (Intake)
P0011 - 008 - Retard Setpoint not Reached (Over-Advanced)
16398 - Bank 1: Camshaft B (Exhaust)
P0014 - 008 - Retard Setpoint not Reached (Over-Advanced)
19:35:01
4 Faults Found:
