Hi,just changed the above electric pump for a new one and it still doesnt work. Fuse 16 is good. Mk4. Any ideas?
Any vag com tests available for this pump?
Cheers N.
Cheers N.
Ile have to check as I've never noticed it on when engine is on, but you can sort of hear it switch on as you turn the ignition off, maybe PM Gaz Jones as he knows the working of them really well.sirgalahad1 said:Hi MIQ yes that's the one, the electric one at front of engine. So yours only runs when you turn off the engine then?
If so that's good for me as it means I only have to fix the broken wire.
