Ok, first up MY SYSTEM IS DRAINED OF AIR CON FLUID/GAS/ETC. & I'm wearing goggles. & I'm using industrial gauntlets. So all good here to work on this area!
Leak in air con drier spotted so fitting new one (yes could replace just O-rings but need a new drier due to age so bitten bullet & bought from Stealers).
I having a 'mare of job getting the hex head (6mm) bolts off on top & underside even after applying the magic mover juice that is WD40. So am thinking, could there be a vacuum inside stopping this? The unit is exactly 10 years on the car so usual elements affecting as well such as road dirt, corrosion (not any visible on heads - see pics below).
I've used an extender rod to give me extra torque but getting into the stage where the whole unit is moving in sympathy & know that the air con supplying pipes are only thin aluminium/alloy & heard horror stories of bodgers knackering pipe-work when they 'remove' unsuccessfully!
Stealer want £260 just to fit the part (3 hour job they 'estimate'!) and would rather spend that on other things so...
(1) Is this problem particular to the AIr Con Drier?
(2) Is this just the normal 'bolt on there since year dot so needs a LOT of WD40 + time + patience'?!
(3) What magic trick would the dealership spanner monkeys do that I don't know?!
Need a bit of quick feedback / help as on a bit of a deadline to get this mother off, replaced, re-gasses & cooooooled dooooooown!
Air Con Drier Whole Unit : Underside / Top / Bottom close-up views of hex bolt
