1 - 4 of 4 Posts
Hi all,
I've had my mk5 R32 for about 6mths and noticed that it takes aprox 5-10mins for the air con to kick out cold air. Now i've done some digging on here and on vwvortex and can only come to the conclusion my HP/LP switch is knackered. Has anyone had a similar issue and resolved it? I don't think its the compressor because it does kick in and blows ice cold air but takes 5-10 to do it. The "technicians" at VW over here in dubai say its normal and there's nothing to fix but I'm unsold on that.
Thanks in advance
sean
I had an A/C problem with same symptoms on my old B6 Passat. Would take about 10-15 minutes before it would start to get cold where as prior to the problem it would generally take only a few minutes tops. Eventually it got worse, took longer and then never got cold.
After a re-gas, pressure test and some more fault finding we discovered that the compressor was knackered. After replacing that it was back to normal and did start feeling cold after a few minutes of being on.
1 - 4 of 4 Posts
