I have a air con leak, which is around a sensor of some sort on the o/s lower engine bay, this sensor is in a air con pipe and the wiring is all wet, however, the surrounding pipes are also wet so I'm not sure where it is coming from, I just wondered if anyone else has had the same problem and if its a common issue?
