1 - 2 of 2 Posts
Hi all,
Right, I will try and cover everything here.
I realised my fans were not working properly, so had a fan fix kit fitted. Small fan worked but big one was dead.
Replaced the fans, had aircon regassed and all worked fine.
4 weeks later, fans stopped working. Had dye put through the system, a leak was detected on the condenser. I replaced the condenser and it was regassed again.
Just checked again, 4 weeks later and the fans have stopped working on 'AUTO' again. Temp outside is 14.5 degrees.
Any suggestions?? Getting to the point of giving up on trying to fix it!!!
Hi Main,I have had huge air con probs so I understand your flustration.
My guess is gas pressure is low....a leak. I understand you had one leak fixed but that does not mean there was not more than one. First step I suggest is to check pressure.
1 - 2 of 2 Posts
