1 - 3 of 3 Posts
Just want to know what value you get in the ABS module Measuring Block 5 when not on the brake pedal and when hard on it. Got a fault registered as below but a new switch hasn't fixed it.
Error is: 01435 - brake pressure sensor - implausible signal (g201)
With the engine started (so the servo working) I'm getting a reading of between -0.14 and .1 bar when no pedal pressure and almost 110Bar when *really* pushing the pedal hard.
Be very grateful if someone could give me their readings...
I changed the brake pressure sensor with 4 pins that attaches to the front of the pedal at the top, the other one is giving the correct on \ off readings when I look at the measurement blocks for it so I assume it is fine?
1 - 3 of 3 Posts
