1 - 4 of 4 Posts
Hi All,
Got to work this morning and the drivers side speakers didn't appear to be sounding as good quality as the passenger side so when I got home, I decided to run a diagnostic ..........
Speakers seem ok now but some other fault codes popped up that i'm curious about and wondered if anybody has any idea what they may be ?
For referennce, the car isn't standard. Different to OEM that could effect readings are;
GruppeM Carbon Air Intake
Supersprint Non Resonated S/S Exhaust
Alpine IVA-W505R Multimedia Stereo System
APS Stage 1 Engine Tune
Can anybody assist in regards to what these faults mean ? What can I check for ?
Thanks in advance,
Scott
VCDS Version: Release 10.6.5
Data version: 20110930
Saturday,08,October,2011,11:55:15:12701
Chassis Type: 1K0
Scan: -----------------------------------------------------------------
VIN: WVWZZZ*********** Mileage: ------------km/-------miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: ----------------------------
Part No SW: --------------------- HW: ----------------------
Component: MOTRONIC ME7.1.1G 6772
Revision: --H02--- Serial number: -------------------------
Coding: 0000172
Shop #: -------------------------
VCID: ------------------------------
1 Fault Found:
000257 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 62759 km
Time Indication: 0
Freeze Frame:
RPM: 989 /min
Load: 14.5 %
Speed: 18.0 km/h
Temperature: 87.0°C
Temperature: 23.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004744
Shop #: WSC 01279 785 00200
VCID: 72E032771434
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70E4387F1A38
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006560180
Coding: E68F8F2700041500471400001400000000087B075C0001
Shop #: WSC 00014 204 81388
VCID: 6CDC2C0F3610
Part No: 1K2 955 119 E
Component: Wischer 151206 020 0501
Coding: 00038805
Shop #: WSC 00014
Part No: 1K0 955 559 AB
Component: RLS 050107 020 0105
Coding: 00207646
Shop #: WSC 00014
1 Fault Found:
00926 - Terminal 30
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 217
Mileage: 45956 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 5.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 2F AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D07N0EY
Coding: 0012870
Shop #: WSC 01269 785 00200
VCID: 6CDC2C0F3610
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74EC346F6E20
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 973 B HW: 1K6 920 973 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8232821
Coding: 0005403
Shop #: WSC 01133 210 66706
VCID: 3260F277D4B4
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 231206F1000687
Coding: FD0F034007000001
VCID: 2F66FB03C786
1 Fault Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 217
Mileage: 16426 km
Time Indication: 0
Date: 2000.00.00
Time: 11:55:28
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3668CE6738DC
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
VCID: 3260F277D4B4
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0982
Coding: 0000564
VCID: 3874C05F32C8
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.141 H07 1806
Shop #: WSC 00000 028 00001
VCID: 356AC96B25DA
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 809002085103087F2D04840570085AC690BC00
Shop #: WSC 01287 785 00200
VCID: 830EE7B3BB8E
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 8003
Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 005 0984
Coding: 0000564
VCID: 3972C55B09C2
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000004
VCID: F4ECB46FEE20
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
Flaccid Member
the can bus one on number 19 is due to the fact that you don't have a vw stereo any more and in the install list of the can bus module you still have 56 ticked so it thinks you have a vw stereo in there, remove the tick and save it fault will clear.
terminal 30 is the battery voltage, i would just reset this one and see if it comes back after a week
with regard to MAF i have no idea
Cool, thanks for that Si......
All fault codes have been cleared so I will check again in 1 week as suggested.
On another note, did you do the DRL's yourself or pay somebody to do it ? Was it an easy job ? Is VCDS required for any coding when installed ?
I'd be interested in seeing how your install looks and the switches involved to turn off/on
Flaccid Member
DRL;s were indeed fully done by me and some help from me dad, i wouldn't say easy but it depends on your DIY skills.
no coding is required due to the fact there fed from there own ignition fed fuse in the end of dash fuse board.
check this out mate it explains it all
http://www.r32oc.com/topic/28452-fittingwiring-a6-drls/
1 - 4 of 4 Posts
