1 - 6 of 6 Posts
I need some advise with my eip stage 1 kit, so if there is someone out there that has it let me know please
Hiya, as said in the other thread. The main problem with the kit is the mapping and the bov (vws dont like true bovs, they dont mind recirculating ones though so alot have people have changed to a forge recirculating bov). C2 motorsport (a company in america) have just come up with a fueling kit which gives you a new map as well as new fueling system (iue injectors fuel pump etc etc) which will basically sort out all your problems.
If you go onto www.vwvortex.com there is alot of info on the c2 guys in the r32 section.
hth
andrew
bro, thank you so much man. its been so stressful and a pain in the rear to deal with this car. how did you get yours to run right? did you use the c2 system? does your car really have the horse power that eip said it made? i love your car dude, its tight!
hth
andrew
hiya, cheers for the kind comments.
Mine was a stage 2 and made 410 on the rollers, with a gone clutch and a 2.5" exhaust. I think with the new clutch and exhaust it would have made 450.
I have decided instead of going c2 to go with vr6 specialist in holland, simply because i dont want to have to deal with the issue of being over the pond again, and would rather be able to take my car to the place. Which i will be doing when its all installed, and will be getting a completely custom map :)
For mine to run right, i change to the forge dv as well as getting the snow performance meth/water injection which did help it alot but in the end a mew remap/fueling system is really needed.
hth
andrew
Just wondering, Are you running lowered compression?
1 - 6 of 6 Posts
