1 - 20 of 28 Posts
.:R32OC Resident Pervert
Well I have booked my R in for a service @ APS just shy of 60K now
I will also be having,
Stage 1 brake upgrade consists of brake fluid replacement using the ATE Super Blue fluid, as my brakes are pants in the wet.
(Just going to see it this helps)
When I contacted VW just to have a nose at prices they did not know what a VW Golf MK4 R32 was ........1.6 ..........Diesel .......etc Gulp !
VW dealers quoted prices from £170.00 to £350.00
But they did not know about the hadex oil change,
APS all the way and not VW (Thanks Ed):vroam:
how often do you need to get the haldex serviced?
Every 40k per the service book, but I'm doing mine every 20k
davefish said:
maybe get some arbs fitted or something
They're well worth having done - I had mine fitted on Friday at APS and am really really pleased with the result.
Forgot to say that APS open on Monday at 11am,
Hope to be first before 11am
Thanks for the vote of confidence chap. Did you have Neuspeed, Eibach or H&R?
EDIT: spotted in sig.
APS fitted my ARB's too (Neuspeed 25mm front, 22mm rears), definately recommend it!
I assume the additional weight of the V6 is the reason for the stiffer front end, but as I have the defcon II bushings and the haldex performance controller, understeer is certainly not something I worry about anymore, and is a reason why I only went for 22mm on the rear rather than 25mm. I just did what Ed advised!!!
For some reason I'd put in my sig that I had Eibach ARB's fitted when it was a actually H&R with 24mm at the front and 26mm at the rear.
Discussion Starter · #13 ·
Going to APS in the morning,
Hope to get great service
I can't fault the service there. I must drop Ed an email and see if he's got the new knob for my Haldex switch yet.
Discussion Starter · #15 ·
Least they know what a R32 is as VW don't know.
Cant wait to get car serviced and brake fuid upgraded and rear spring replaced.
Burble drop Ed a email mate.
You will do mate, guaranteed.
Don't forget to ask for a doughnut, Ed's always got some hiding somewhere!
Discussion Starter · #18 ·
Matt and Tony sorry I did not ask for doughnuts, Drat.
Well I felt very welcomed indeed,
I had 60 K service
Engine oil,
Pollen filter,
Oil filter,
Oil filter,
Haldex oil,
ATE Blue brake fluid,
(Replacement Coil spring)
And Regas air con
All for 339.41
Happy days.
Very good service and nice cups of tea from Ed,
also had a sausage and egg sandwich from down the road
Discussion Starter · #19 ·
Come on own up, Who has there R at APS as there was TWO MK4'S and one Mk5 R32's
And some called Ed and asked about a stage THREE on a R32 ........Anyone ?
What colours and perhaps part reg numbers?
1 - 20 of 28 Posts
