1 - 9 of 9 Posts
Hi
Does anyone know about the haldex on the tt tdi mk2 an what gen of haldex it is. A friend has had his go saying its the pump on the laptop but its believed the pump alone can't be changed.
In sure when you turn the key ignition you hear the Pre charge pimp same as ours but he reckons he can't anymore. Can't find number for fuse for it as mk1 is # 31.
Just last resorts before he changes the haldex unit.
Eats Kitty Litter
Yes i know but depending on the year is which gen haldex is fitted.
It's a 09 tdi. Got 3 bolt holding in apparently easy to sheer off. Fault code said it the pump as said before but he took off also a little bit longer filter an the one GSF gave him was shorter so he's confused as said its for his model/year. Also is haldex oil quite thin. I read that someone once put haldex oil in diff oil plug but only 275 ml haldex and 9.5 lt for diff I believe.
Eats Kitty Litter
2007-2008.5 is Gen 2
2009- present is Gen 4
Eats Kitty Litter
1 - 9 of 9 Posts
