Hi All,
New to the forums and first time posting after nearly tearing my hair out with my Audi 3.2.
A little background to the fail is as follows:
- Regularly got temp sensor fault so fan would annoyingly run unless error cleared in OBD, easy enough and had no effect on the car running at all UNTIL…
- I went to clear the code last week and the OBD socket had no power going to it at all. Trying to stop the fan from running for some reason I pulled Relay 458 out, this stopped the fan from running until I could diagnose which fuse to replace for the diagnostics port.
-When replacing the fuse I accidentally pulled fuse 29 ECU Fuse (10a) instead of the correct Fuse 13 Diagnostics / Brake light.
- The dreaded PRNDS flashed at me along with a few other warning lights, I replaced both fuses and turned the ignition off.
- I then went to start the car and the fuel pump wouldn’t prime or run so I have a no start cranking situation.
- I have replaced the Fuel pump relay to no effect and I can start the car and run it by slaving a 12v to the fuel pump. This obviously runs it extremely rich as I’m getting white smoke from the exhaust which I suspect I unburnt fuel.
I have read online that there can be a J30 polarity reversal that relates to the oxygen sensors and the fuel pump relay but I’m not sure where I would start with this. I have attached the error codes I’ve got below. Please if you could spare any knowledge on this I would be extremely grateful. I’m reasonably competent with Auto Electronics and will try my best to understand wiring schem’s. Thanks I’m advance , Kieron
PS: The cooling fan seems to run intermittently for a few seconds at low speed every now and again; and I can also get the car to prime the fuel pump by resetting the ECU ( + & - connected for 10s) but it still won’t run after it initially starts ie. Fuel pump not supplying fuel.
Car Scanner ELM OBD2
Version: 1.98.6/1.98.6/iOS
DTC report
Connection profile: Audi OBD-II / EOBDDate: 17/05/2023 17:35:04
OBD-IIOBD-II
DTCs: 5
P0057 [0x0057]
Heated oxygen sensor (HO2S) 2, bank 2, heater control - heater circuit low
HO2S Heater Circuit Low Voltage Bank 2 Sensor 2
Status: Confirmed
P0037 [0x0037]
Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit low
HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
Status: Confirmed
P0230 [0x0230]
Fuel pump relay - circuit malfunction
Fuel Pump Relay Control Circuit
Status: Confirmed
P0141 [0x0141]
Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit malfunction
HO2S Heater Performance Bank 1 Sensor 2
Status: Pending
P0161 [0x0161]
Heated oxygen sensor (HO2S) 2, bank 2, heater control - circuit malfunction
HO2S Heater Performance Bank 2 Sensor 2
Status: Pending
19. CAN Gateway
No DTC found.
09. Onboard supply control unit
No DTC found.
03. ABS control unit
No DTC found.
01. Engine control unit01. Engine control unit
DTCs: 10
16441 [0x4039]
P0057 Bank 2 Sensor 2: Short to ground in the electrical heating circuit; Bank2-Probe2, Heater Circuit Short To Ground
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
16421 [0x4025]
P0037 Bank 1 Sensor 2, electrical heating circuit: short to ground; Bank1-Probe2, Heating Circuit Short to Ground
17949 [0x461D]
P1541 Fuel pump relay-J17: open circuit; Fuel pump relay-J17 open circuit
Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
17522 [0x4472]
P1114 Row 1, probe 2 internal resistance too high; Bank 1, probe 2 internal resistance too high
17548 [0x448C]
P1140 Row 2, probe 2: internal resistance too high; Bank 2, probe 2 internal resistance too high
00087 [0x0057]
Terminal 30 for connecting consumers affecting start-up; Terminal 30 for start-relevant consumers; Bank2-Probe2, Heater Circuit Short To Ground
00055 [0x0037]
The motor lock the rear left door from accidental opening from the inside-V142; Motor for child safety lock, rear left-V142; Bank1-Probe2, Heating Circuit Short to Ground
00560 [0x0230]
Exhaust gas recirculation system; Fuel pump relay-J17 electrical fault in the circuit
00321 [0x0141]
Rear Door Hydraulic Sensor-G383; Tailgate hydraulic sender-G383; Bank1-Probe2, Heating Circuit Electrical Failure
00353 [0x0161]
Supply fan controller confirmation signal; Function feedback controller for fresh air blower; Bank2-Probe2, Heating Circuit Electrical Failure
08. Heater and climate
No DTC found.
52. Front passenger door electronics
No DTC found.
55. Headlights corrector
No DTC found.
56. Head unit (MMI) (VW TP2.0)
No DTC found.
