hey folks.just got my boost gauge fitted but when the engine is off the gauge reads two digits below 0!!!
am i right in thinking this means it is reading two digits less psi when its at max pressure?
how do i sort this???
Mine sits at -20 which is what the guys in the US reads at around the same altitude, When you put your foot down it should rise and when you’re at around 4K+ it should be pushing up towards the 6.5psi mark. And when you take your foot off it should gradually come off as the car slows (unlike a turbo) I don't think you’ve got anything to worry about!
when im idling the gauge reads -20 in hg!!
after 0 it then goes into psi??:dontknow::hmmmm:
ok cool thanx guys!!!must be ok then!!
dosent quite make 6psi like but i havent given it a proper thrashing yet!
iv only got stage 1.shood you not be hitting 9 psi with stage 2??
Sounds good to me! I think you get 6.5 with stage 2 and 6.2 with stage 1 IIRC.... If you have a leak somwhere you may be loosing some but i'm not sure how accurate these gauges are.
oh well they look cool anyway so im happy enuf!!!
cheers for your advice mate:rock:
