1 - 4 of 4 Posts
Cutting Edge Member
Can anyone help please??? As above. Drivers door will not lock, even with key?!?!?! Getting this code:-
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
I noticed the led was flashing different to usual and as soon as I open the door the alarm goes off, whilst all other doors are locked. Now I have no way of locking the drivers door.
Regards
Senior Onion collector
Your door latch has failed pal, quite a common problem on all MK5 Golfs after a few years.
Door skin off job & the parts around £170 via VW...........or get a copy part for around £60
Cutting Edge Member
Thanks Dazm. Anyone have a part number.
Cutting Edge Member
Took the door panel off this morning and found the door release wire was not on properly. put it back to how it should be and voila its working again. i had took off the panel a few months ago maybe happened then and not noticed.
1 - 4 of 4 Posts
