1 - 6 of 6 Posts
Had a wheel alignment done today due to have the front wishbone bushes replaced and on the screen could see the camber is an issue also. The strange bit is the driver side is .5 degree worse than the passenger side and 1 degree worse on the drivers side than the passenger! It's on coilovers, running just the springs at the back. I can see that the driver side is lower than the passenger but the coilovers are set he same. I suspected top mounts on the front?? But what about the back?
Sent from AutoGuide.com App
Administrator
Hi mate there are threads on here about mk Iv R32's apparently if you measure on flat ground the rear passenger is about 5 to 10 mm higher but levels when driving
I can not remember the reason why
Administrator
Obviously when you fit coil overs or air you can adjust accordingly but just springs you get the slightly higher side
Administrator
rwoody29 said:
Ah thanks mark! That solves the rear issue then, phew!
And just lower the near side a bit more on the coil ey
1 - 6 of 6 Posts
