1 - 12 of 12 Posts
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 022 906 032 CP
Component: MOTRONIC ME7.1.1G 6463
Coding: 0000132
Shop #: WSC 00690
1 Fault Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 P
Component: ESP ALLRAD MK60 0101
Coding: 0023049
Shop #: WSC 31414
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31414
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 926 J
Component: KOMBI+WEGFAHRSP VDO V20
Coding: 05410
Shop #: WSC 00000
WVWZZZ1JZ3D509934 VWZ7Z0C7917395
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31414
Address 22 -------------------------------------------------------
Controller: 02D 900 554 C
Component: HALDEX LSC ECC 0010
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: BZ Komfortgerát HLO 003
Coding: 00064
Shop #: WSC 31414
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
Address 56 -------------------------------------------------------
Controller: 3B7 035 195 A
Component: Radio DE2 0014
Coding: 0000403
Shop #: WSC 31414
End -------------------------------------------------------
the problem my golf r32 has developed recently is as follows, when startin the car from cold when i accelerate the engine note is very quiet and bit like an echo. this is really noticable as ive got a carbonio cai, also when this is happening the engine note does not change at 4k rpm when the flap in the inlet manifold opens up. acceleration is a bit poor as well and sometime going up the revs it kicks in and then is perfect after that and sounds spot on. also ive found that even in this cold weather ive got no cold start it just tats and idles at around 800rpm. it used to have the cold start even in summer when it was chilly morning.
also the sunroof has stopped working and i belive that the central convienience module has given up. as new motor and switch didnt sort it out and with that fault code i think that narrows it to that.
if anyone could help or confirm that the engie temp sensor is at fault for my poor engine sound and off par acceleration under 4k rpm, it would be much apriciated!
cheers gaz
A dodgy engine temp sender causes numerous different problems including ones you've mentioned.
Judging by the fact ures has shown as faulty i'd just replace it as its about 20quid and a 5 min job, so maybe it WILL cure it.
As for the sunroof, the fault code is stating the convenience unit so i'd say your right about that. If that codes shown i cant see it being the motor or switch or it may have thrown a different code.
Lets know how you get on tho if you do change the temp sender, be interested to know.
i looked on the ross tech website and put in the fault number and it mentioned the poor acceleration idling and things. mine has the green one so surprised its actually gone!
does a loda of cooland poor out when changing it. take it its just a circlip holding sensor in?
what is that for? nothing up with the aircon. unless the central convienience moduel is intergrated in the climate control.
just looked mine hasnt got the green temp sensor so im going to go get a green one and hope that sorts the problem out
You will lose very minimal coolant , just make sure the cars cold when you change it or you'll scald your fingers with hot coolant.
cheers for that your fault looks the same as mine, and my tail pipes are really sooty as well!cwill get this changed soon as possible. did you car underperform below 3.5k mine was struggling to put past bloke on bike in second gear this morning!
Yes I had that same problem when the temp sensor had gone. under 3.5k rpm it would seem sluggish, but then a kick in the back and all would be fine.
APS fitted my new sensor for about £30 (done along with my remap and millteks :top: )
When my sensor went u/s, it sounded if the exhaust was blowing and performance was down. I lost about 1.5l of coolant when I changed mine.
Not too sure weather i have a problem if that makes sence but after reading the thread on cold start its got me thinking my r starts up fine and runs well from cold but it only seems too tick over fast in the warmer climate this cold snap we r having at the moment it dont seem to tick over fast from cold but it seems to perform ok is it me worring about nothing also have notice the exhaust pipes a bit sooty:willy:
mine didnt show an loss in perormance til recently but i cant remember last time it idled over 1k from a cold start. and my pipes did get very sooty!
1 - 12 of 12 Posts
