1 - 18 of 18 Posts
Just spent a little bit of time cleaning my milltek pipes.
Used autosol and a wire brush attachment for my drill (only used this on the INSIDE)
not bad for a quick job, drill does an impressively quick job
Before:
After :
Good work Steve - I am going to get one of these attachments - mine a pretty clean on the outside, but a little sooty on the inside.
edit to say - I am sure my pipes are bigger - or at least look it. I can only just clean the sides of mine - you seem to have a fair bit of space on the left hand side.
macdaddy said:
the left pipe needs slightly adjusting to the left.
Mine needing adjust slightly when I had mt cats fitted. they stuck out too much.
Got it sorted when the manifolds were done.
Look good steve! what is the best cleaning product for stainless steal? my miltecs need a clean!
I used several coats of T cut metal polish and a scouring pad, it was time consuming but well worth the effort.
I found the silver polish that you can get with the wdding, usually next to drasso, is really really good for this, come in a silver and blue can (sorry cant remember the name).
when i picked mine up they looked lke they had never been cleaned took me a good 2 hours with wet and dry and metal polish but now look super not a spot of black on them! but good work on them steve
.:R32OC Resident Pervert
Humm ,My standard exhaust looks like the above but the inner metal is very pitted on the inside.
I will have to have a go at cleaning them again but with a wire drill attachment .
mate you dont need it all you need is three products and you can do each in about 3-5 mins. The three are:
1 - 0 gauge wire wool
2 - metal polish
3 - autosmart tardis
and by spraying on some tradis then with the wire wool and metal polish, it will come off very very quickly and to a superb finish.
hth
andrew
2 - metal polish
hth
andrew
Hi Andrew
I have just saved this to my favorites and just want to know what tradis is ?
Thanks young man
Just wondering if anyone else noticed when you've done a long journey in the R do your tailpipes stick out about another inch?
Obviously metal expands when it gets hot but I didn't realise it would expand that much!
Also I need to re-adjust one of my tailpipes, is it fairly easy to do or will I need to put more exhaust grease on when I do it?
caxton01 said:
Hi Andrew
Thanks young man
Its basically i highly solvent based product (i think its a solvent) its also very very very good at getting rid of tar from the bodywork.
Oh and the tailpipes do stick out when they get hot :)
1 - 18 of 18 Posts
