1 - 20 of 23 Posts
Hi all, I've owned my R32 now for a couple of months and absolutely love it. Recently I've heard a clicking noise in the engine bay, I've changed the alternator pulley and belt tensioner but I still have the noise. Any ideas on what I should check next? Many thanks
Is it constant when the engine is idling or can you hear it when driving? Is it a low sounding fast click
Sent from my ST18i
Isn't it the charcoal fllter - this is quite normal!
As above, it's probably the charcoal filter.
No, it's not dangerous and perfectly normal.
It is the black canister with pipes coming out of it on the left of the engine bay next to the screenwash filler tube.
I have heard that part clicking continuously , this noise happens every now and then, it's that loud I can hear it from inside the car with the windows shut.
That's very loud!
Have you run VCDS? It's very easy and scary to speculate over a PC
Paul20031975 said:
What's vcds cheempeej ?
It's basically the software for diagnostics. A deer can do it or some members have it and will do anything you like for a small fee
Are you sure it's coming from the engine bay?
You often get clicking from behind the dash as the motor controlled flaps get out of sync and drive against the end stops.
Injectors and chains tick in relation to engine speed but not loud enough for you to hear inside the cabin.
Vcds is a way of looking and programming the cars functions. You can look at error codes that may not show on the dash lights and clear them if you are happy. I bought my interface cable from Ross-tech.com in USA. They are like having a spare tyre for your car, you can get by without one but it will save you when needed.
Sent from my RM-821_apac_australia_new_zealand_304 using Board Express
1 - 20 of 23 Posts
