i had the same sort of feeling and it ended up i needed a new top strut bearing.but if you have had new suspension wouldnt think that would be the problem mate??
No new suspension - all original... Would the top strut bearing not mean that it did it every time you went full lock? Or would that be a reason for it to seize and then be ok again?andyr32 said:i had the same sort of feeling and it ended up i needed a new top strut bearing.but if you have had new suspension wouldnt think that would be the problem mate??
Cheers Sarah, I'm hoping its just that. exhaust sounds great.... are the carbonios in yet? They were expected weeks ago!Awesomesarah said:Hi
If the car had been stood for a while it could be freeing up
Or the springs can tend to spring with a twang
Are you still having these problems? If so give us a call and we can have a look for you
Glad we could sort you out too
Sarah
I'll tell you this weekend - mine's going in for its haldex service tomorrow, so I'll see if they can change them.... from what everyone's saying, this is worth doing after a while anyway (even if you haven't had clunks).. cheers allsilver r said:any idear how much dealer charges for stut top bearing to be replaced? is there an better after market bearing which will last longer? is this a job that you can do yourself or do you need specialised tools etc? seems this is a common fault! be handy if we could change these ourselfs to keep the running costs down.
