1 - 12 of 12 Posts
A rust spot has suddenly appeared inside the sill of my rear door I've also got small bubbles appearing on o/s wheelarch would I be right in thinking this shouldn't be happening so soon on a 2007 mk5
No the car is completely standard with full service history only mod is change if alloys but they are the same size as originals
Wings is a common issue and if the car still has the original paintwork then VW shoyld repair it under the 12 year anti-corrosion warranty. Take the car to a VW dealer, they will check paint depth and hopefully they will agree fo resolve the issue. VW are aware of the issue with corrosion on MK5 front wings. Do a search, plenty of threads on the subject with varying outcomes.
Sill is harder as it could have been caused by a chip. The warranty only covers corrosion from the inside out and not if the paint surface is chipped or broken.
As Bob says, you have a good case for the wings with it being standard FSH etc, chance your hand with the sill but unlikely. **** on here (BLACKMK4SUPERCHARGED) only got 50% of his doors done so sills are unlikely.
Good luck either way
apologies for stealing thread here but since we are on the topic on corrosion
Has any of you guys heard of a manufacturers fault of the boot on a MK5??
the edges of the boot rub against the bumper causing white scuffs/corrosion?
When I spoke to the tech a vw about my wings (still waiting on vw to get back to me) he said that people get the warranty wrong, its a perforation warranty on bodywork this excludes bolt on panels Inc wings , vw are only doing the repairs on the wings as a good grace gesture hence they will only offer 50% help, this was only because so many people come forward with the complaint .....
How do MK4s compare for rusting? I don't think I've ever seen a rusty MK4 R!
My mate had an 08 plate MK5 and whilst we were under it fitting the haldex sport switch, I noticed the floor was rusting in places already!
Common rust problem on the Mk5's my mates got a GTTDI and its rotten! He does try to look after it too!
VW should definitely sort it, i think they changed the galv on the body work at some stage and this is what is causing so many to rust
1 - 12 of 12 Posts
