1 - 8 of 8 Posts
Will disconnecting my battery for a few hours cause any issues when I reconnect it?
And where is the battery located ?
In a Mk5 Golf, in the boot
In an Audi no clue!
I think it's in the boot in a 3.2 Audi A3 as well.
It will do no harm to disconnect for a few hours.
You shouldn't need the radio code but have it handy just incase.
When you start the car after reconnecting the battery the ABS and ESP lights may stay on but should go out after a short drive to recalibrate the steering angle sensor
On some vehicle if you leave the battery off for 24 hours it resets the ecu, this can be good because it puts the ecu into learning mode and learns how you drive. I know this works for a lot of cars including my navara.
Battery is normally in the front under the scuttle panel on audi's
Cheers alexmac that's what I heard from before and used to do it on my old vxr made the remus exhaust pop more when I done it, as for location of the battery in my Audi I'm pretty much a r32 with a different clothes so battery same as you mk 5 guys
1 - 8 of 8 Posts
