Do you need to lower the subframe to remove the down pipes on a mk4 R32 ??
R32dara · Junior Member Joined May 19, 2012 · 405 Posts Discussion Starter · #1 · May 1, 2013 Only show this user Do you need to lower the subframe to remove the down pipes on a mk4 R32 ??
PaulW · Premium Member Joined Jun 6, 2012 · 14,955 Posts #2 · May 1, 2013 Only show this user You can do it without dropping it but its not easy. Just cut them, not worth much anyway, good excuse to upgrade which you will ned anyway
R32dara · Junior Member Joined May 19, 2012 · 405 Posts Discussion Starter · #3 · May 1, 2013 Only show this user I need to save them as someone wants them , or they would of been cut off lol
PaulW · Premium Member Joined Jun 6, 2012 · 14,955 Posts #4 · May 1, 2013 Only show this user Good luck! You dropping the subframe anyway?
R32dara · Junior Member Joined May 19, 2012 · 405 Posts Discussion Starter · #5 · May 1, 2013 Only show this user I would like to do it with out dropping it it if I can help it
Lucifer · Eats Kitty Litter Joined May 7, 2010 · 6,640 Posts #6 · May 1, 2013 Only show this user For the pissing about your going to go through just cut them as they sell for £40 unless somebody is intending to pay you stupid money for them.
