Hi
Has anyone experienced these symptoms, has had diagnostics done and no faults showing
Sometimes when turning at junctions and small traffic islands gears seem to slip as if clutch has been put down when you reduce revs it corrects itself but car usually selects 1st gear causing high revs . This only happens when the car is moving and turning either left or right and you start to accelerate from low speeds
Does not slip when accelerating in a straight line only when turning left or right
