1 - 4 of 4 Posts
Not for the R32 specifically no. Plenty of standalones can run the R32 though. Why, are you going forced induction?
FWIW, I ran my old R32 on a DTA S80 with DBW controller and it worked really well.
OK, well the aforementioned DTA S80 + STC controller (for the throttle) will run the engine just fine at the sensible money end of the market at ~£1400ish. It has dual lambda and can control the cams and COPs (Coil on plugs). The only thing missing is knock sensor support but I can supply you with a base map that worked just fine and never pinked.
At the other end of the scale we have the Motec M600 at ~ £2300ish which also supports DBW and knock, but you have to pay extra to 'unlock' these features.
There's also ecumaster which I think are a Polish company and the ECU is pretty cheap by today's standards, but it has everything, MAF, knock, DBW, the lot.
1 - 4 of 4 Posts
