hi guys
my R32 problem
my engine light came on randomly one day so went to my mates garage and we checked it on vcds
the fault code is 001112 - evap system purge control (n80)
P0458-002-short to ground -mil on
so i replaced the purge control valve as i thought that was the problem light still on after reset
so he checked the wiring to the purge valve ..ok
wiring to the ecu ...ok
checked the wiring when running ..purge valve is opening and closing as it should
its just this light fault ...
the car runs fine but the management light stays on its like the ecu isnt talking to the clocks and wont reset
any ideas would be appreciated
thanks Ged
my R32 problem
thanks Ged
