This has happened 2 or 3 times in the past couple of months.
It seems like random, during a drive, without warning, the EML comes on, and stays on for the journey. It might be off by the next journey, or the next day. The car seems to be running absolutely fine, so what could be causing this, emissions? I have been doing alot of very short journeys lately.
It quote literally could be anything, so you need to do a scan with VCDS to see what codes are stored andcwhat's triggering it.
Would a brake switch not bring the ABS light on, if any light at all. EML is engine related.
Crusie control is related with the Engine ECU so possible if it senses the cruise control isn't working.
But as Bob says, you are shooting in the dark without knowing the fault codes. Get it scanned with VCDS
