Hi on my drive home last night my car started playing up and the performance dropped, i scanned it with VCDS and it came up with these faults
000768 random/multiple cylinder misfire detected
p0300 - 001 - intermittent - mil on
000769 cylinder 1
p0301 - 001 - misfire detected - intermittent 0 mil 0n
readiness: 0000 1101
i reset the fault this morning and went for a drive and it was fine, i looked on the VCDS fault codes and it listed loads of different reasons why this may be happening, anyone got any ideas before it comes back ? thanks.
My guess would be the coilpack or spark plug on cylinder 1 is on it's way out.
Cool i will order a coilpack just in case it comes back, if im looking at my engine from the front is cylinder 1 first on the left ?
Stick to OEM coilpacks from either dealer or TPS.
You could swap cylinder No.1 coilpack with No.6 coilpack to confirm if problem follows coilpack.
Sorry, can't remember if cylinder 1 is one nearest gearbox or as you say left looking from the front.
Eats Kitty Litter
I have a few spare used ones laying about if you just want a spare for £12 posted each.
