1 - 15 of 15 Posts
Got the following error - 16538 - Oxygen Lambda B2-S1 P0154-008-No Activity-MIL ON. I know this means that a Lambda Probe is faulty but from the code is there anyway of telling which Probe is at fault?
I was thinking along them lines but still doesn't tell me whether its pre-cat or after cat?
looks like passenger side pre-cat sensor. Anyone know if these are a bi*ch to get off as I would say with all the heat from exhaust gases if its the original one then it will be welded in there?
BAnk one is drivers side, Bank two is passenger
I would buy one from TPS or the likes so your not stuck and can return it if it does break
Discussion Starter · #13 ·
cheers Jon. was yours pre-cat? if so did you fit them yourself and if so were they difficult?
I orignally thought mine where faulty but it was just the way I was testing them. Still thought it was best todo them while i was doing the manifold and cat upgrade.
1 - 15 of 15 Posts
