1 - 3 of 3 Posts
Hey chaps, I wonder if you can give me a bit of advice please.
I've been trying to fit a CAI, specifically the BMC CDA, but have got stuck trying to figure out how to get the cold air pipe down to air dam.
The original air box is attached to a moulded plastic tube, which leads to a plastic shroud which surrounds the light housing. Now there isn't room around this shroud to squeeze the cold air pipe down to the lower dam, so I presume I have to remove this shroud right? If so, how do you do it? I can see 2 plastic plugs holding it in place, which look like I would have to break them to remove them (which will be difficult in itself), but it feels like there is a third plug holding the shroud in below the light which I can't get to.
Do I have to remove the whole light housing to get this bit of plastic out, or is there a trick I'm missing to getting this cold air pipe fitted?
Fantastic, thanks Chris. It seems I need to get to the third lug from the wheel well, which I wouldn't have even considered :) Cheers!
1 - 3 of 3 Posts
