1 - 10 of 10 Posts
Quick questions guys, I bought a osir splitter second hand for my mk5 and it has already been drilled, the holes look like they were for a nut and bolt, not a screw if you get me.
I was under the car looking and if I am going to use the nut and bolt method ill have to take the bumper off obviously?
Does anyone use self tappers and screw it in or is that a bit caveman?
Lol. I Havnt a clue about things like this so thought best to ask. So bumper off nut bolt and washer?
Sounds like you know what your doing
yep, stainless steel button heads if possible M6 - M8 with penny washer either side
Senior Onion collector
Cheers mate thank you!!! Is the front bumper hard to remove? Prolly 200 torx screws lol
Grille off 1st pal, then work your way round and find all the torx screws, there in the front arches too as well as underneath-takes me around 45 mins to remove my front nowadays
Or find someone with a ramp local?
To be honest you could actually do it without removing the bumper and just remove the side grills and the main grill. This should give you more than enough access
1 - 10 of 10 Posts
