Hi,
I plan on buying a set of Lucifer's front pipes when he can get the next lot made. How difficult are these to fit?
I tend to do most of the work on the cars I own and looking at the car, they seem pretty straight forward to remove. However, I contacted EMP Performance about getting a system fabricated and the front pipes fitted and they want £200 to fit the front pipes! Seems a little excessive to me?!
Cheers,
Paul
Discussion Starter · #2 ·
Anyone?
All you guys with the decats must have to remove and refit the front pipes every year?!
Paul
youngsyp said:
Anyone?
Paul
Not if you fit sports cats or know a friendly mot tester. :) sorry I can't help, not a mk5 man
Eats Kitty Litter
They just bolt on to the Mk5 manifold. I don`t own a MK5 but if you can get to the exhaust end of the manifold should be straight forward other then the nuts will probably be a bitch to remove because of the heat but that`s he same with all manifold/exhaust bolts.
Wheel Whore!
Jack up the front and go wild with the grinder. It goes without saying the bolts on the old system will be rather moth eaten.
Wheel Whore!
Your supposed to check your nuts daily
