Photobucket fail
Yes mate I do them, perhaps didn't make that clear enough on that first cluster post. Photo over load!Who does these Franko yourself?
I have the fade on my LCD display in higher temps in th top corners.
Although it isn't that bad at moment but it's something I want to address.
Ok nice one, I shall bear it in mind, another job to do on my to do list.Yes mate I do them, perhaps didn't make that clear enough on that first cluster post. Photo over load!
Don't suppose you'd know how to properly code my dension Bluetooth kit in? Supposed to be able to access music menu to choose songs but so far only got the phone menu to work. I can listen to music but it won't access the artists etc etc. Was a VCDS step to do on CAN- gateway to activate something but it wasn't in the list when I lookedPS I'll be going to GTi International this coming weekend so if anyone needs any VCDS / Vag Com action let me know, might be able to see you there.
It's a decent clone but can't update that's all. Would you be able to take a look at inters if you have yours with you? Literally just needs that box ticking and it should be there because it's got updated CAN gateway in from when the RNS510 was fitted by previous owner. I posted ages ago by the way and no one replied despite numerous bumps lol even tried Facebook VCDS users uk and no replies.I've never touched one of those before, but your VCDS looks ancient, is it a dodgy eBay/China knock off? Wonder if it can't fully recognise all the options in your gateway? Unless I'm mistaken yours is showing as version 14.10.0, mine is 17.1.3 (official licensed cable setup).
There might be MK5 guys who have more experience of this if you post it in the "In Car Entertainment" section on here:
http://www.r32oc.com/forum/7-in-car-entertainment/
Will be good to have a chat fella.Cool, hopefully I'll spot you over there then
Take it you know that you can read oil temperature off the 3.2 ECU as standard without an external sensor?I have oil pressure and temperature sensors to wire into my FIS Control just not got around to doing it, this might give me the empathise to do it
Because motorsport?Yeah knew it could read the temperature, assume it's from the sump level sensor? I have a billet oil filter holder with space for both pressure and temperature sensors and INA baffled sump so no sensorImageUploadedByAutoGuide1496161382.279743.jpg![]()
