1 - 20 of 20 Posts
Can someone recommend a supplier for the LED lights to carry out a full conversion on the interior lights and rear number plate.
I want to make it OEM if possible, and was thinking if the MK6 R lights can be used. I am also not sure if there will be any issues with carrying this out. Any help is much appreciated.
I have set yet to be fitted there is a guy on mkv GTi forum who sells the whole set !
Is there any other issues to look out for. ie: battery drain or canbus issues?? I am not sure on the pros and cons of doing this.
Is the guy on mkV GTI forum using OEM items?
No there not !
It's after market stuff but with no dash errors !
Anyone know where I can get the full interior/exterior conversion kits? i.e the mKV Gti bloke etc? not a member on there forum
I bought mine from hidsdirect,they are based in swinton,Manchester
No error codes
Number plate LEDs and all the interior bulbs including boot and footwells
Sounds ace mate
Thank you! Il google them tomo... Unless you have some contact details you could pm me?
Have you done ur side lights etc???
Bringing up an old thread I started a while back, but having looked at many queries on carrying out an LED upgrade on the interior lights, can anyone help me with the part numbers for OEM golf LED bulbs? If not, does anyone know the strength of LED's used on a standard car. I just don't want the light output to be OTT from aftermarket suppliers.
I'm pretty sure there is no OEM solution for the interior lighting or most of the exterior lighting in fact. As I understand it, the only OEM LED replacement you can buy is the rear numberplate lamps.
I'll have a dig around and find you links to what I used. None of them are over the top in terms of output and the colour is just right too, in my opinion. They're all canbus friendly and importantly, have some longevity testing under them too.
Paul
Discussion Starter · #14 ·
Paul
Thanks Paul - much appreciated.
ive just done this on mine, full boldsport kit. really pleased with them
I used this seller from ebay for mine and had no problems at all.
http://www.ebay.co.u...984.m1423.l2649
Just got this kit , was fitting the bulbs then all of a sudden both visor bulbs , interior light bulbs and glovebox one stopped working .. Tired old ones still no luck is there a fuse for these might of went . Any help will be great
Thanks Gary
Thanks Gary
It's the brown 7.5amp fuse located in the fuse box in the end of dashboard side trim on the drivers side.
https://www.google.co.uk/search?q=golf+mk5+r32+interior+light+fuse&client=ms-opera-mobile&channel=new&espv=1&biw=360&bih=485&source=lnms&tbm=isch&sboxchip=Images&sa=X&ei=64XKVPmWBM6Q7AbXhYCwCA&ved=0CAYQ_AUoATgK&dpr=2#imgrc=sm0UaRxsWTviUM%253A%3BKYQm32VNhoPtlM%3Bhttp%253A%252F%252Fi1135.photobucket.com%252Falbums%252Fm625%252Fusualsuspect1%252Fa1af5a3f.jpg%3Bhttp%253A%252F%252Fwww.mk5golfgti.co.uk%252Fforum%252Findex.php%253Ftopic%253D51545.0%3B764%3B1024
Handy tip is to pull that out each time you fit the new bulbs.
1 - 20 of 20 Posts
