Hey!
I have little problem.I swapped Phaeton 3.2 engine to my golf 3.I'm almost done with swap,but injector wont open.With brake cleaner it will start,but dies,because ecu wont open injectors.
Heres few DTC:
P0686 - ECM Power Relay Control Circuit (J271): Short to GND
P0230 - Fuel Pump Relay (J17): Malfunction in Primary Circuit
I'm using PHAETON 2 ECu supply relays and G3 vr6 original fuel pump relay.
What wiring i should check?
http://wiki.obdtuning.com/images/a/ac/VAG_ME7.x.jpg ,these are allready connected and good.I can see engine rpm signal.
But now I Have injector DTC :S
P0276 Fuel Injector 6 short to ground
P0261 Fuel Injector 1 Short to ground
P0267 Fuel injector 3 short to ground
P0273 Fuel injector 5 short to ground
P0270 Fuel injector 4 Short to ground
