1 - 4 of 4 Posts
i have an a3 tdi Quattro are they the same system as the golf/r32/etc.the fault is said to be in the control unit.have the yellow dash light on.this morning it never came on.would that mean its working?anyone able to fix/service repair these units in uk
Eats Kitty Litter
You need to get a fault code to work out which part is playing up. No the haldex controller and pump do not get fixed.
There is info on the net about rebuilding the precharge pump and / or replacing it with a pump from a Volvo / Saab / Vauxhall / Mazda etc, which all use Haldex.
The pump is horrific money from VW, but Lucifer usually has a good stock of them!
If it's not the pump and ECU related, there isn't much you can do about it other than replace it.
1 - 4 of 4 Posts
