Has anyone seen if the rabbit non xenon headlights are plug and play if I want to get rid of the stock r32 headlights. I have seen it done the other way where rabbit guys put the xenon housings in with a wiring harness adapter. But I want to do the opposite. My assemblys are falling apart and very hazy. So I was looking to just get a set of cheap non xenon headlight assemblys and because I want LED bulbs any way.
2008 R32
2007 5dr DSG RS R32
They're not plug and play. Different wiring and connectors so you'd need a reverse adapter as most of them are intended for going from halogen to xenon. You'd also need to code out the xenons with VCDS.
2007 5dr DSG RS R32
Try and find a good set of used genuine xenons. I run 6000K HID bulbs in mine with a 6000K LED high beam, indicator and parking light and they're much better than the original bulbs.
