1 - 15 of 15 Posts
Hi - first post... :hello:
I'm a bit of a R-head... Here a a few picys of my R32's....
Firstly my Mk4...
Spec...
Dieselgeek shortshift linkage
Superchipped
Miltek stainless back box with twin 4" tailpipes
Miltek high flow sports cats
AEM cold air intake
Schrick 264° Intake Camshaft mated to 260° Exhaust Camshaft
ECS 335mm front brake disc upgrade
ECS 296mm rear brake disc upgrade
Neuspeed Front Upper Strut Brace
Neuspeed Aluminium Engine Bay Caps
ECS upgraded engine mounts
Pentagon light smoke tint
Beetle sport alloy pins
VW oem sat nav
VW oem tv tuner
Alpine 6 disc changer
Genesis 4 channel amp
Diamond audio 6" component front speakers
Diamond audio 10" sub
Audio control EQ
Alcantara Boot build.
W8 Passat interior light
Snooper 815
Snooper radar blinder...
I had a brief spell with a focus ST:alberteinstein: and then traded it for my MkV R32....:bootyshake:
Anyway mods so far on the mkv - milltek, stereo install... I have a set of KW variant 3 coilovers on the way along with a change of wheels and a APS 300bhp conversion:call2:
Soooooo... on with the picys...
And a couple of my stereo install...:bootyshake:
lovely cars, and welcome to the forum!
You are the inspiration for me and macdaddy with your mk5 boot build, we are going for the same style!! hope you dont mind, but it just works so well! :D
That was some spec list you had on the Mk4, someone must have got a bargain when you sold that !!
Again nice boot build in them both too, gonna try go for the mk5 look one you've done in my mk4.
What sub and amps have you got in there ? also is the amp lit ?
lol.... Not a problem....
But hopefully when I attend edition38 there wont be loads of similar builds.....
The build is totally focal stuff....:aetsch:
Focal 5 channel amp...
Focal K2P 11" sub
Focal K2P 1" tweeter
Focal k2P 4" mid
Focal K2P 6" mid bass...
Amp and sub are both lit up....:playingball:
must have cost a pretty penny then! im just planning my CarPC build. gonna use an Alpine 4channel amp for surround sound, and i have a 10" sub from my old car which i will use.
We wont be doing these builds for a while mate lol dont worry.
are the side panels built for the mk5 etc or did you make them ?
sorry for all the questions, just if i do one i want to get it looking good, not like some corsa max power thing
Everything in the car is custom built... No moulds or anything have been taken...
You need to make sure you installer is up to the job... someone like SQ+ in Manchester would be appropiate!
Very nice mate
Hi Martyn, welcome to the site.
I'll be buying a new Mk5 in the summer. I'm planning on fitting the full Milltek system and I'd be interested in hearing your thoughts on how you've found it? Also, what's involved in the APS 300BHP conversion? And finally how does the Mk5 compare to the Mk4? (sorry for all the q's)
Dave
Hi Dave...
The New R is a fair bit faster.... But nowhere near as "raw" as the mk4...
The suspension on the mk4 could only be described as being hard and the exhaust noise was much louder...
The new car is sooo much more quiet and the ride quality is more grown up....
Is sort of like comparing a race car to a luxury car..
As for the APS conversion... They install cams, miltek exhaust(which I already have) remap and filter...
Hope this helps...
Thanks for the reply chap, I've heard reports that the full Milltek coupled with a remap is likely to have a negative effect on low end torque and it may be best to stick with the cat back only. Did the guys at APS mention this to you when you spoke with them?
At the moment I'm thinking of the following mods:
  • Milltek
  • BMC filter
  • Haldex controller
  • H&R Anti Roll Bars
  • Remap (APS, AMD, Revo, etc... - not sure)
  • KW Variant 3
  • HPA Short Shifter
  • Colour Coded Rear Valance
Any advice/thoughts on the above would be greatly appreciated.
Discussion Starter · #14 ·
  • Milltek
  • BMC filter
  • Haldex controller
  • KW Variant 3
  • HPA Short Shifter
I have heard -ve comments about the milltek manifolds and sports cats... However there is one lad on tyresmoke (brakesnake?) who has them fitted along with the cams and custom map - he made 307bhp on superchips RR...
Take that as you will... but the APS car - without exhaust made 295bhp... so the manifolds seem to give a little more when coupled with the cams and ramap...
However at £1250 + vat they are expensive!:stoned:
I have a set of KW variant 3 on there way..... so I am hoping to get them fitted along with cams and remap at the same time!
APS seem to be the boys when it comes to this tuning stuff:reddy:
1 - 15 of 15 Posts
