1 - 14 of 14 Posts
anybody out there handy with disarming a factory immobiliser/or more than likely realigning it with the ECU??
In short the instrument cluster has lost the SKC code for the immobiliser after trying to get the needles lit and won't talk to ECU I'm in a predicament can anyone help?!!?
VAG4life
Dodders said:
Oh dear, this is the second problem I've now heard about this weekend with enabling MTe and the like,its why i won't touch anyone elses car.
The nearest chap i know who could help you is in hemel unfortunately not much good in getting there.
No dodders I AM that person.....I'm just looking to see if anyone can help before I hit up VW to get it sorted. Contact has been made with the Hemel guy but I can't wait till weekend was gonna put it out there to see if anyone can help...Jon unfortunately the lad and I are nt fluent with vag tacho/vag com. I understand the principle bein that I use diagnostics with BMW on s daily basis, I just don't know how to work this operating system.
I think it is merely aligning the alarm system with the ECU or recoding the cluster with the correct SKC code...excuse y ignorance if I'm incorrect. I just need my car working again
If anyone in the Bristol area understands what I'm saying I would reward your help. These are the screenshots of the issues I have if this helps. Thanks
Computer Personal computer Netbook Laptop Output device
Personal computer Computer Font Laptop Line
As you can see by the above shot the code has been reset to 0000
VAG4life
The best way to fix this is to get the skc from the ecu using vag Commander or super vag scanner
Then code it as if you fitting second hand clocks if you do it right it will copy the vin info over from the ecu
And keep the skc the same as before you then can then recode the keys to the clocks
Just hope you've not fu#k up the clocks more than it looks
Pays to get the skc before you start
That way if you mess up like this you have a way back
Discussion Starter · #13 ·
Thanks mate I hope so too! Should be having a specialist come look at it, I need this car goin whatever it takes but it needs to be sooner rather than later.
VAG4life
1 - 14 of 14 Posts
