Hi all,
I took my 55 reg Mk V R32 on 59k miles to VW today to investigate ESP warning light. The initial diagnostic showed up a G201 ABS Pump fault code which was repaired free of charge. However, the ESP warning light came on again and a subsequent diagnostic identified an underlying fault with the Haldex ECU. The Head Technician said I'm looking at £2,868 + VAT for an All-Wheel Drive Control Module (Part Number 0AV 525 010K) plus 4 hours labour !!!
I have a 6 page hard copy print-out of the function test log which doesn't really mean a great deal to me but here's what I believe to be the relevant fault code information:
01324 013 All-Wheel Drive Control Module -J492- Read Fault Memory sporadic
00924 009 Relay for headlamp cleaning system -J39- Open circuit/short to Ground (GND) static
00003 014 Control module faulty sporadic
02248 014 Haldex Clutch Control Valve -N373- faulty sporadic
Does this diagnosis sound right, is there anything else I should be checking and if worst comes to worst any thoughts on where I could source this part at a human price?
Thanks in advance,
South Bodge
Thanks in advance,
South Bodge
