1 - 20 of 22 Posts
Hi guys
I really need your help here. How often do you have to top up your water and coolant?
I have had the "STOP - Check Coolant" warning come up again today. This is about the second time it has happened within the past three months. I am having to top up with water/coolant about every 5/6 weeks, is this common? I have checked for leaks and can not see anything.
I have mentioned this to other people and have been told that "its a big engine". Am I just being a girl?
Thanks.
Oh no sorry to hear this. I would defenately say something is wrong as i have never had to top up my coolant in the 2.5 years of owning the car, i would say you have a leak somewhere. One thing to check would be that the lid is done up problem.
I've never had to top up my coolant apart from when I changed the coolant temp sensor. I do check regularly. I would get it checked out properly if I was you. Be carefull you don't water down the coolant too much or it will loose it's anti freze properties and that could mean trouble if it get we get a really cold spell.
Never seen it appear on my mkiv when i had it.I think the dealer topped it up,when in at normal service intervals?mind you was only averaging 4k a year.
I'd start checking all the water system connections, all it would take is a rotten seal on one of them which will leak a little over the space of weeks and run it down. Look for the tell tale pink stains........
Fiona said:
Hi guys
Thanks.
I haved this problem about 60 days ago on my MkV .:R , only 1 time ...
But my car is new (9000 km)...
Hi guys!
Thanks for all the advice. It has since been diagnosed, that the rubber seal on/around the theomostat housing has a split in it, so it was leaking. It is being fixed on Wednesday.
In the menatime I have to drive my bf GTI!! :hahaha:
Thanks again x
Mine has been doing this intermittently too for a couple of weeks, but the coolant level is fine. It had a diagnostic on Friday for the emissions warning light and this wasn't picked up so I'm at a loss as to what it could be... I've noticed its been cold out whenever it has done it, but each time I've just turned the engine off and on again and its gone away......:wtf:
DOMR32 - the problem you have is EXACTLY the same i have - only happens when cold and goes ut if I switch ignition off/on again (sometimes needs to be turned off/on 2 or 3 times), coolant level looks fine - i'm buggered if I know what's causing this. I'll try and get it diagnosed in the next few days:(
I got this in my anni yesterday, spoke to my mate at VW and his GTI turbo done it, apparently a duff sensor in the coolant bottle, new bottle later his was fixed, and his done it every time the car was started
Managed to solve this oe, thankfully nothing wrong with the car.... checked coolant evel when STOP warning came on, noticed coolant was right on minimum level. Topped up with a little water (not much, just enough to take level to max with cold engine). This morning outisde temp is -4 degrees, no STOP warning!!!
The prblem seems to have been when the coolant is right on minimum and the outside temp is near or below freezing, the coolant may contract enough to trigger the coolant level sensor... i noticed that the coolant expansion cap wasn't on fully tight, that would explain the gradual trickle reduction in coolant.
Water on its own does indeed expand - remember that 40+ % of your coolant will be G12, the rest will be water. My advice to anyone with this problem - check your coolant level when the engine and coolat is stone cold. If it is on minimum top up the coolant. If it works, cool, better than forking out for a sensor if it aint really needed! If topping up coolant doesn't work get it checked out on VAGCOM. Just relieved mine is sorted.:wink:
Same as me the garage put it down to the lid not done up tight enough on the head tank!
.:R32OC Resident Pervert
Just wanted to know can you buy a basic VAG COM reader
I took my GF to work and had STOP COOLANT , I know its getting colder now and I have let the car cool down .
Going out soon to look and see if any leaks or the top is done up tight
Any advice please ?
Any advice please ?
Happy days !
Just topped up with about two mugs worth of water and cleaned the contact and went out for a drive and all ok now !
Must just be the cold weather and the water had just dropped a bit in the over-flow top up tank. :marchmellow:
I've had this problem today. Not driven my car for about 2 weeks as I've been on crutches, fired it up, and the coolant level light came on. Popped the bonnet and the leves are fine. Had a look in the manual, it says if the level isn't low it could be the rad fan fuse. Checked that ontop of the battery... it was fine... turned car off and on and away it went.
Is this possibly related to the fan issues that happen on the mk4... as my fans appeared to have stopped working....which is quite worrying.
Anyone?
I had this same issue. Took my car in for a service 2 weeks ago and they pressure tested it and found nothing so just topped it up. I reckon it's just to do with the cold weather
Mine definately isn't. Swapped the 30A fuses over ontop of the battery and now I'm looking at my ABS light on permanently.
Joy.
1 - 20 of 22 Posts
